.NET
Active Contributor
1 Kudo
Post 1 of 31
How to get Block's Layer name?
653 Views, 30 Replies
04-18-2012 01:38 AM
After searching for a long time on the web, does anyone know how to get the block's layer name?
I iterate through Blocks to get informations but i'm not able to code the source to obtain what i want?
Sample source taken from AutoCAD.NET site:
 Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            '' Step through the Block table record
            For Each acObjId As ObjectId In acBlkTblRec
                acDoc.Editor.WriteMessage(vbLf & "DXF name: " & acObjId.ObjectClass().DxfName)
                acDoc.Editor.WriteMessage(vbLf & "ObjectID: " & acObjId.ToString())
                acDoc.Editor.WriteMessage(vbLf & "Handle: " & acObjId.Handle.ToString())
                acDoc.Editor.WriteMessage(vbLf)
            Next
            '' Dispose of the transaction
        End Using
 Maybe use nested transaction to iterate through LayerTableId?
ideas?
171 Kudos
Post 2 of 31
Re: How to get Block's Layer name?
04-18-2012 01:42 AM in reply to: MGOMKD
Try this function to get the block name
		Public Shared Function EffectiveName(blkref As BlockReference) As String
			If blkref.IsDynamicBlock Then
				Using obj As BlockTableRecord = DirectCast(blkref.DynamicBlockTableRecord.GetObject(OpenMode.ForRead), BlockTableRecord)
					Return obj.Name
				End Using
			End If
			Return blkref.Name
		End Function
~'J'~
Active Contributor
1 Kudo
Post 3 of 31
04-18-2012 01:52 AM in reply to: MGOMKD
Hi Hallex,
I don't want to get the block's name but the layer's name on which the block is attached!
Thanks a lot.
171 Kudos
Post 4 of 31
04-18-2012 02:01 AM in reply to: MGOMKD
Sorry for that
To get a layer you have to cast object as Entity, something like:
                    Dim ent As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                    acDoc.Editor.WriteMessage(vbLf & "Layer: " & ent.Layer.ToString())
                Next
                ''Dispose of the transaction
            End Using
~'J'~
Active Contributor
1 Kudo
Post 5 of 31
04-18-2012 02:09 AM in reply to: Hallex
What the...
It  was so easy that i didn't see it! I'll try this.
You're the fastest and the best Hallex!
See you.
PS: I'm French, so all apollogies to my syntaxe script.
Active Contributor
1 Kudo
Post 6 of 31
04-18-2012 04:57 AM in reply to: MGOMKD
yeah it works!
171 Kudos
Post 7 of 31
04-18-2012 05:08 AM in reply to: MGOMKD
Glad to help
Cheers :smileyhappy:
~'J'~
Active Contributor
1 Kudo
Post 8 of 31
07-30-2012 12:38 AM in reply to: Hallex
Hi Hallex,
How are you? I have a new matter that i cannot solve.
You helped me to find le layer's name of a block.
Now i would like to find property's block (AcadObject: Polyline, Arc....). For instance for each block in a particular layer, iterate through each ones, then showing all properties like length,  boundary closed or opened, width....
'Compte du nombre d'objet(s) dans le calque séléctionné'
                Using acTrans = acDocs.MdiActiveDocument.Database.TransactionManager.StartTransaction()
                    acBlkTbl = acTrans.GetObject(acDocs.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead)
                        Dim MyEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                        If MyEnt.Layer = LayerVal Then
                            'MsgBox(acObjId.ObjectClass.DxfName)
                            Select Case acObjId.ObjectClass.DxfName
                                '* ARC *'
                                Case Is = "ARC"
                                    'LENGTH'
                                    MsgBox (?)
                                Case Is = "CIRCLE"
                                Case Is = "DIMENSION"
                                Case Is = "HATCH"
                                Case Is = "LINE"
                                Case Is = "LWPOLYLINE"
                                Case Is = "MTEXTE"
                                Case Is = "POINT"
                                Case Is = "RAY"
                                Case Is = "REGION"
                                Case Is = "TEXTE"
                                Case Is = "SPLINE"
                                Case Is = "XLINE"
                            End Select
                        End If
                    Next acObjId
                End Using
            End With
 Do you have any ideas?
Active Contributor
1 Kudo
Post 9 of 31
07-30-2012 02:38 AM in reply to: MGOMKD
I think i could find a way through this link!
Through the Interface
171 Kudos
Post 10 of 31
07-30-2012 05:17 AM in reply to: MGOMKD
This will get you started, I have no time on complete solution
Change properties for every type what you'll want to retrieve
Here is just a quick example:
        <CommandMethod("getsubentitiesinfo", "GetS", CommandFlags.Modal)> _
        Public Shared Sub explodeRef()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim info As String = ""
            Dim opts As New PromptEntityOptions(vbLf & "Select block reference")
            opts.SetRejectMessage(vbLf & "Select only type of block reference!")
            opts.AddAllowedClass(GetType(BlockReference), False)
            Dim res As PromptEntityResult = ed.GetEntity(opts)
            If res.Status <> PromptStatus.OK Then Return
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim bref As BlockReference = TryCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), BlockReference)
                Dim expobjs As New DBObjectCollection()
                bref.Explode(expobjs)
                Dim table As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                For Each obj As DBObject In expobjs
                    If TypeOf obj Is Entity Then
                        Select Case obj.GetRXClass().DxfName
                            Case "LWPOLYLINE"
                                info = ""
                                Dim poly As Polyline = TryCast(obj, Polyline)
                                info = String.Format(vbLf + "Number of points: {0}" + vbLf + "Closed? {1}" + vbLf + "Layer: {2}" + vbLf + "Color: {3}", poly.NumberOfVertices, poly.Closed, poly.Layer, poly.ColorIndex)
                                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(info)
                            Case "ARC"
                                info = ""
                                Dim arc As Arc = TryCast(obj, Arc)
                                info = String.Format(vbLf + "Center: {0}" + vbLf + "Start angle: {1}" + vbLf + "End angle: {2}" + vbLf + "Start point{3}" + vbLf + "End point: {4}" + vbLf + "Layer: {5}" + vbLf + "Color: {6}", arc.Center, arc.StartAngle, arc.EndAngle, arc.StartPoint, arc.EndPoint, arc.Layer, arc.ColorIndex)
                                ''ETC..ETC...
                            Case "CIRCLE"
                            Case "DIMENSION"
                            Case "HATCH"
                            Case "LINE"
                            Case "LWPOLYLINE"
                            Case "MTEXT"
                            Case "POINT"
                            Case "RAY"
                            Case "REGION"
                            Case "TEXT"
                            Case "SPLINE"
                            Case "XLINE"
                        End Select
                    End If
                Next
                'clean up memory, optional
                    obj.Dispose()
                Next
                tr.Commit()
            End Using
        End Sub
~'J'~
