.NET
how to get and set the color of 'drafting tool tip'?
8 REPLIES 8
Message 1 of 9
swaywood
729 Views, 8 Replies
Hi all:
I want to set the color of drafting tool tip,contour,background and the tip font size.
could anyone tell me how to do?
8 REPLIES 8
Message 2 of 9
swaywood
in reply to: swaywood
Message 3 of 9
swaywood
could anyone help me?
Message 4 of 9
swaywood
Is there any one know this?
Please help me.
Message 5 of 9
Jeff_M
It appears these settings are stored in the Registry under the user Profile, Tooltip section. I don't have any example code to test with right now, but you should be able to get to this using the UserConfigurationManager class.4-9-2014 6-21-32 AM.png
Jeff_M, also a frequent Swamper
Message 6 of 9
swaywood
thank you so much, jeff, but our company's computer can not visit the register table.
it there any system value?
Message 7 of 9
norman.yuan
Yes, your company computer can and must "visit" Windows Registry. It just that what part of it can be changed, depending on the login user's permissions.
The "...Profiles->[profile Name]->Tooltip" Jeff showed is in HKEY_CURRENT_USER section of the Windows Registry, which is per-user based, and can be read/write accessed by any user who runs AutoCAD in the computer.
Norman Yuan
Drive CAD With Code
Message 8 of 9
Jeff_M
in reply to: Jeff_M
OK, the UserConfigurationManager and corresponding IConfigurationSection object cannot be used with these properties, they only work with strings (REG_SZ type in the registry). Since these entries are of the type REG_DWORD they would need to be edited using standard registry editing techniques.
Message 9 of 9
swaywood
in reply to: Jeff_M
Hi,jeff and yuan:
thank you very much, i'll try it.
regards
swaywood
”Boost
