.NET
how to get an object ID
2 REPLIES 2
333 Views, 2 Replies
i am using vb.net , and i am now trying to obtain the id of a certain selected object.
firstly i will promote a message and ask users to select one object, and later, obtain the ID of this object.
what command or function avalible for me to obtain the ID of a selected object.
2 REPLIES 2
Ajilal.Vijayan
you can try below code to get the object id of a selected object.
 <CommandMethod("TST")> Public Sub TESTObject()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select an object:")
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Return
        Dim id As ObjectId = per.ObjectId
        MsgBox(id.ToString)
    End Sub
”Boost
