.NET
Valued Contributor
netcai
Message 1 of 8 (263 Views)
how to get all plot configurations?
263 Views, 7 Replies
07-25-2005 08:33 AM
I want to list all configurations in a dwg in a listbox, but how to get all plot configurations?
Valued Contributor
netcai
Message 2 of 8 (263 Views)
Re: how to get all plot configurations?
07-29-2005 04:19 AM in reply to: netcai
no one can help me?
*Paul Richardson
Message 3 of 8 (263 Views)
07-29-2005 04:42 AM in reply to: netcai
Help menu has an example
wrote in message news:4910090@discussion.autodesk.com...
Valued Contributor
netcai
Message 4 of 8 (263 Views)
07-30-2005 04:15 AM in reply to: netcai
this is dot net forum, so what i want is a method using dot net api,not activex method.
*Paul Richardson
Message 5 of 8 (263 Views)
07-30-2005 05:19 AM in reply to: netcai
you didn't say that
wrote in message news:4915554@discussion.autodesk.com...
activex method.
*Albert Szilvasy
Message 6 of 8 (263 Views)
07-31-2005 10:34 AM in reply to: netcai
And what's the difference? Do you have some requirements that make it
impossible to use the COM objects from your favorite .NET language?
Albert
activex method.
Valued Contributor
netcai
Message 7 of 8 (263 Views)
07-31-2005 06:04 PM in reply to: netcai
what i mean is why not dot net api can't do it.
Active Contributor
Chris Ludtke
Message 8 of 8 (263 Views)
08-03-2005 09:07 AM in reply to: netcai
I am not an expert. That can be verified by some of my dim-witted postings heron.
I have been working on a project that uses the .Net interface to create postscript files using AutoCAD Mechanical 2006.
Here is some code that may help. I am sure that you this may help you get a listing of the available PlotSettings (aka PlotConfigurations through the COM interface)
You should be able to past this function into the "HelloWorld" sample.
_
Public Function HelloTextCommand()
Dim oAcadDB As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim oAcadEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'Get Value of the "BackGroundPlot" system Variable
Dim oAcadCOMApp As Autodesk.AutoCAD.Interop.AcadApplication = CType(AcadCOMintf.AcadApplication, AcadApplication)
Dim ExistingBGPVal As Short = oAcadCOMApp.ActiveDocument.GetVariable("BACKGROUNDPLOT")
Dim NewBGPVal As Short = 0
oAcadCOMApp.ActiveDocument.SetVariable("BACKGROUNDPLOT", NewBGPVal)
oAcadCOMApp = Nothing
oAcadCOMApp = CType(AcadCOMintf.AcadApplication, AcadApplication)
'Find BlockReference for Format "d1+format" on Layout - Layout2
Dim oTypedValues() As TypedValue = { _
New TypedValue(DxfCode.Start, "INSERT"), _
New TypedValue(DxfCode.BlockName, UCase("d1+format")) _
Dim oAcadSelectionFilter As New SelectionFilter(oTypedValues) ' Create the filter using our values...
Dim oAcadSelectionResult As PromptSelectionResult = oAcadEditor.SelectAll(oAcadSelectionFilter)
Dim oAcadSelectionSet As Autodesk.AutoCAD.EditorInput.SelectionSet = oAcadSelectionResult.Value
If oAcadSelectionSet Is Nothing Then
MsgBox("No TestFormat Found")
Exit Function
End If
Dim oAcadIDArray As ObjectId() = oAcadSelectionSet.GetObjectIds()
Dim oAcadTransactionManager As Autodesk.AutoCAD.DatabaseServices.TransactionManager = oAcadDB.TransactionManager
Dim StartTime As Date = Now
Dim oAcadTransaction As Transaction = oAcadTransactionManager.StartTransaction()
Try
Dim oObjectID As ObjectId
Dim oBlockRef As BlockReference
Dim oObject As DBObject
For Each oObjectID In oAcadIDArray
oObject = oAcadTransactionManager.GetObject(oObjectID, OpenMode.ForRead)
If TypeOf oObject Is BlockReference Then ' get layout
oBlockRef = CType(oObject, BlockReference)
Dim oBlockOwnerRefObjectID As ObjectId = oBlockRef.OwnerId
Dim oOwnerBlockTableRecord As BlockTableRecord = CType(oAcadTransaction.GetObject(oBlockOwnerRefObjectID, OpenMode.ForWrite, False, False), BlockTableRecord)
Dim olayoutObjectID As ObjectId = oOwnerBlockTableRecord.LayoutId
Dim oLayoutID As ObjectId = oOwnerBlockTableRecord.LayoutId
Dim olayout As Layout = CType(oAcadTransaction.GetObject(oLayoutID, OpenMode.ForWrite, False, False), Layout)
Dim oLayoutManager As Autodesk.AutoCAD.DatabaseServices.LayoutManager = Autodesk.AutoCAD.DatabaseServices.LayoutManager.Current
oLayoutManager.CurrentLayout = olayout.LayoutName ' sets Layout1 active
Dim oAcadViewTable As Autodesk.AutoCAD.DatabaseServices.ViewTable
oAcadViewTable = CType(oAcadTransaction.GetObject(oAcadDB.ViewTableId, OpenMode.ForWrite, False, False), ViewTable)
Dim oAcadViewTableRecord As Autodesk.AutoCAD.DatabaseServices.ViewTableRecord
Dim oAcadViewTableRecordID As Autodesk.AutoCAD.DatabaseServices.ObjectId
Dim strName As String = "TestView"
Dim blnViewExist As Boolean = False
For Each oAcadViewTableRecordID In oAcadViewTable ' search for a view with the same name in the table
oAcadViewTableRecord = CType(oAcadTransaction.GetObject(oAcadViewTableRecordID, OpenMode.ForWrite, False, False), Autodesk.AutoCAD.DatabaseServices.ViewTableRecord)
If oAcadViewTableRecord.Name = strName Then
blnViewExist = True
Exit For
End If
Next
If Not blnViewExist Then 'if not, make a new view table (oAcadViewTable is open via a ForWrite transaction above)
oAcadViewTableRecord = New Autodesk.AutoCAD.DatabaseServices.ViewTableRecord
oAcadViewTable.Add(oAcadViewTableRecord)
oAcadViewTableRecordID = oAcadViewTableRecord.ObjectId
oAcadTransactionManager.AddNewlyCreatedDBObject(oAcadViewTableRecord, True)
End If
For Each oAcadViewTableRecordID In oAcadViewTable ' open ViewTable for Write
blnViewExist = True
Exit For
End If
Next
oAcadViewTableRecord.Layout = olayout.ObjectId
oAcadViewTableRecord.Width = 34.0
oAcadViewTableRecord.Height = 22.0
Dim strCenterPoint As New Autodesk.AutoCAD.Geometry.Point2d(oBlockRef.Position.X + 17.0, oBlockRef.Position.Y + 11.0)
oAcadViewTableRecord.CenterPoint = strCenterPoint
oAcadViewTableRecord.ViewTwist = 0.0
oAcadViewTableRecord.CategoryName = "Test Viewport Category"
Dim oAcadPSDictID As ObjectId = oAcadDB.PlotSettingsDictionaryId
Dim oAcadPSdict As DBDictionary
Dim oPSVal As PlotSettingsValidator = PlotSettingsValidator.Current
oAcadPSdict = CType(oAcadTransaction.GetObject(oAcadPSDictID, OpenMode.ForWrite, False, False), DBDictionary)
Dim oDictEntry As DictionaryEntry
Dim PSExist As Boolean
Dim PSObjectID As ObjectId
Dim PSisLayout As Boolean
Dim strPSName As String = "TestPlotSetting"
For Each oDictEntry In oAcadPSdict
If oDictEntry.Key = strPSName Then
PSExist = True
PSObjectID = oDictEntry.Value
Exit For
End If
Next
Dim oPlotSettings As PlotSettings
If PSExist Then
oPlotSettings = CType(oAcadTransaction.GetObject(PSObjectID, OpenMode.ForWrite, False, False), PlotSettings)
Else
oPlotSettings = New PlotSettings(False) ' False Paperspace, True ModelSpace
oPlotSettings.PlotSettingsName = strPSName
oPlotSettings.AddToPlotSettingsDictionary(oAcadDB)
oAcadTransactionManager.AddNewlyCreatedDBObject(oPlotSettings, True)
For Each oDictEntry In oAcadPSdict ' Adding the PlotSetting to the dictionary modifies the Object ID.
' This operation resets the PlotSetting object
Exit For
End If
Next
End If
With oPSVal
.RefreshLists(oPlotSettings)
.SetPlotConfigurationName(oPlotSettings, "AutoCAD PostScript File Writer.pc3", "UserDefinedImperial (34.00 x 22.00Inches)")
.SetDefaultPlotConfig(oPlotSettings)
.SetStdScale(oPlotSettings, 1)
.SetUseStandardScale(oPlotSettings, True)
.SetStdScaleType(oPlotSettings, StdScaleType.StdScale1To1)
.SetPlotRotation(oPlotSettings, PlotRotation.Degrees000)
.SetPlotPaperUnits(oPlotSettings, PlotPaperUnit.Inches)
Dim oWindow As New Autodesk.AutoCAD.DatabaseServices.Extents2d(oBlockRef.Position.X, oBlockRef.Position.Y, oBlockRef.Position.X + 34.0, oBlockRef.Position.Y + 22.0)
.SetPlotWindowArea(oPlotSettings, oWindow)
.SetPlotType(oPlotSettings, Autodesk.AutoCAD.DatabaseServices.PlotType.Window)
Dim oCusScale As New Autodesk.AutoCAD.DatabaseServices.CustomScale(1.0, 1.0)
.SetCustomPrintScale(oPlotSettings, oCusScale)
.SetPlotCentered(oPlotSettings, True)
.SetZoomToPaperOnUpdate(oPlotSettings, True)
.SetCanonicalMediaName(oPlotSettings, "UserDefinedImperial (34.00 x 22.00Inches)")
.SetCurrentStyleSheet(oPlotSettings, "monochrome.ctb")
End With
Dim oPlotInfo As New Autodesk.AutoCAD.PlottingServices.PlotInfo
Dim oPageInfo As New Autodesk.AutoCAD.PlottingServices.PlotPageInfo
Dim oPPD As New Autodesk.AutoCAD.PlottingServices.PlotProgressDialog(False, 1, False)
Dim oPlotEngine As Autodesk.AutoCAD.PlottingServices.PlotEngine = Autodesk.AutoCAD.PlottingServices.PlotFactory.CreatePublishEngine
oPlotInfo.Layout = olayout.ObjectId
oPlotInfo.ValidatedSettings = oPlotSettings
oPlotInfo.OverrideSettings = oPlotSettings
Dim oPIValidator As Autodesk.AutoCAD.PlottingServices.PlotInfoValidator = New Autodesk.AutoCAD.PlottingServices.PlotInfoValidator
oPIValidator.MediaMatchingPolicy = Autodesk.AutoCAD.PlottingServices.MatchingPolicy.MatchEnabled
oPIValidator.Validate(oPlotInfo)
System.Windows.Forms.Application.DoEvents()
With oPPD
.PlotMsgString(PlotMessageIndex.DialogTitle) = "Creating PostScript Files required for PDF Creation"
.PlotMsgString(PlotMessageIndex.SheetName) = " Test Sheet Name : "
.PlotMsgString(PlotMessageIndex.SheetName) = " Sheet Name Text"
.PlotMsgString(PlotMessageIndex.Status) = " Status name Text "
.LowerPlotProgressRange = 0
.UpperPlotProgressRange = 100
.IsVisible = True
.OnBeginPlot()
End With
With oPlotEngine
.BeginPlot(oPPD, Nothing)
.BeginDocument(oPlotInfo, "Test Document Name.dwg", Nothing, CInt(1), True, "C:\temp\Test.ps")
.BeginPage(oPageInfo, oPlotInfo, True, Nothing)
.BeginGenerateGraphics(Nothing)
.EndGenerateGraphics(Nothing)
.EndPage(Nothing)
oPPD.PlotProgressPos = 100
.EndDocument(Nothing)
.EndPlot(Nothing)
oPPD.IsVisible = False
End With
Dim EndTime As Date = Now
Dim Ts As System.TimeSpan = EndTime.Subtract(StartTime)
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine + "Total Elapsed Time (seconds,milliseconds) : " & Ts.Seconds & " : " & Ts.Milliseconds & " .... ")
If Not oPPD Is Nothing Then
oPPD.Destroy()
oPPD.Dispose()
oPPD = Nothing
End If
If Not oPageInfo Is Nothing Then
oPageInfo.Dispose()
oPageInfo = Nothing
End If
If Not oPlotInfo Is Nothing Then
oPlotInfo.Dispose()
oPlotInfo = Nothing
End If
If Not oPIValidator Is Nothing Then
oPIValidator.Dispose()
oPIValidator = Nothing
End If
If Not oPlotEngine Is Nothing Then
oPlotEngine.Destroy()
oPlotEngine.Dispose()
oPlotEngine = Nothing
End If
If Not oPlotSettings Is Nothing Then
oPlotSettings.Dispose()
oPlotSettings = Nothing
End If
If Not oPSVal Is Nothing Then
oPSVal.Dispose()
oPSVal = Nothing
End If
End If
Next
oAcadTransaction.Commit()
oAcadTransaction.Dispose()
oAcadTransaction = Nothing
oAcadTransactionManager.Dispose()
oAcadTransactionManager = Nothing
oAcadSelectionFilter = Nothing
oAcadSelectionSet = Nothing
oTypedValues = Nothing
oAcadIDArray = Nothing
oAcadEditor = Nothing
oAcadDB = Nothing
Catch ex As Exception
End Try
End Function
I think that you may be interested in the PlotSettings dictionary portion of the above code
