.NET
How to Get all opened documents(drawings)
1 REPLY 1
vinayan
670 Views, 1 Reply
I am using AutoCAD 2012 and the .NET API. Can someone help me how can i loop through the document objects of all the open documents? i am trying to do something like the code below..
public void GetDocNames()
            DocumentCollection docs = Application.DocumentManager;
            for (int i = 0; i < docs.Count; i++)
                AcadDocument doc = docs[i];
                Debug.Print(doc.Name);
Tags (2)
1 REPLY 1
AubelecBE
in reply to: vinayan
For Each element As Autodesk.AutoCAD.ApplicationServices.Document In Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
.. your code.
        Next
with this you have all open document
”Boost
