.NET
dreamwtx
Message 1 of 8 (1,285 Views)
How to get all names of layers in a drawing by traversal layers using c#?
1285 Views, 7 Replies
03-14-2012 09:32 PM
I want to get all names of layers in a drawing ,and then  put them in a array.  how to carry out it.
Hallex
Message 2 of 8 (1,279 Views)
Re: How to get all names of layers in a drawing by traversal layers using c#?
03-14-2012 10:35 PM in reply to: dreamwtx
I think easier to gather layer names to List of string
then you can easy to convert to array using
List.ToArray() method
Here is a quick sample:
// This method can have any name
        [CommandMethod("DisplayLayers","displa", CommandFlags.Modal)]
        public void TestDisplayLayers()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            List<string> info = LayersToList(db);
            foreach (string lname in info)
                ed.WriteMessage("\nLayer Name: \t{0}", lname);
        public List<string> LayersToList(Database db)
            List<string> lstlay = new List<string>();
            LayerTableRecord layer;
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                foreach (ObjectId layerId in lt)
                    layer = tr.GetObject (layerId, OpenMode.ForWrite) as LayerTableRecord;
                    lstlay.Add(layer.Name);
            return lstlay;
~'J'~
Valued Contributor
Paulio
Message 3 of 8 (1,255 Views)
03-15-2012 10:02 AM in reply to: Hallex
Just curious Hallex, what's different about "StartOpenCloseTransaction" as opposed to "StartTransaction"?
Hallex
Message 4 of 8 (1,252 Views)
03-15-2012 10:11 AM in reply to: Paulio
To be honestly I did not read Arx docs about this
I use it when I just do nothing in the drawing,
as in this case to read something from document only
:smileyindifferent:
Member
Radnus_87
Message 5 of 8 (711 Views)
09-26-2013 12:08 AM in reply to: Hallex
Thanks for Posting this routine. But i need to get the list of layer names which are turned on in current drawing not all the layers in the drawing. How to get it
Valued Contributor
Paulio
Message 6 of 8 (706 Views)
09-26-2013 12:15 AM in reply to: Radnus_87
You could test the IsOff property of the LayerTableRecord before adding it to the list:
                    if (!layer.IsOff)
You could also test for IsFrozen if required...
_gile
Message 7 of 8 (698 Views)
09-26-2013 01:08 AM in reply to: Paulio
Member
Radnus_87
Message 8 of 8 (693 Views)
09-26-2013 01:16 AM in reply to: Paulio
Got it..Thanks for your reply :smileyhappy:
