.NET
.NET
Active Contributor
0 Kudos
Post 1 of 3
How to get all MLeaders, even in Blocks nested ones?
183 Views, 2 Replies
08-13-2013 10:12 PM
Hello alltogether,
I need to EnableFrameText to all MLeaders in a drawing,
I also want to get the MLeaders who are nested in Blocks
automatically...
I started this way but It just works fine with the Mleaders in Modelspace
or if I open the Blockeditor to edit Mleaders nested in a Block...
I know I'm not going to "deep", maybe I need an other Transaction,
or thirst open each Block to edit... not right sure...
maybe I'm on a wrong way, absolutely...
can somebody help me?
Thank you :smileysurprised:)
my example:
        //Ändert leider nur die MLeader die nicht in einem Block sind....
        [CommandMethod("MLeaderIterator")]
        public static void MLeaderIterator_Method()
            Database database = HostApplicationServices.WorkingDatabase;
            using (Transaction transaction = database.TransactionManager.StartTransaction())
                BlockTable blkTable = (BlockTable)transaction.GetObject(database.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btRecord = (BlockTableRecord)transaction.GetObject(blkTable[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                foreach(ObjectId id in btRecord)
                    if(id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(MLeader))))
                        MLeader _mLeader = (MLeader)transaction.GetObject(id, OpenMode.ForRead);
                        if (_mLeader.EnableFrameText == true)
                            _mLeader.UpgradeOpen();
                            _mLeader.EnableFrameText = false;
                            _mLeader.TextColor = Color.FromColorIndex(ColorMethod.ByColor, 240);
                            _mLeader.DowngradeOpen();
                transaction.Commit();
Just iterate all BlockTableRecords in the BlockTable.
A 45 second refactor from previous snippet
IntPtr mleaderPtr = RXClass.GetClass(typeof(MLeader)).UnmanagedObject;
foreach (ObjectId btRecordId in blkTable)
BlockTableRecord btRecord = (BlockTableRecord)transaction.GetObject(btRecordId, OpenMode.ForRead);
if (!(btRecord.IsDependent || btRecord.IsFromExternalReference || btRecord.IsAProxy))
foreach (ObjectId id in btRecord)
if (id.ObjectClass.UnmanagedObject == mleaderPtr)
Valued Mentor
53 Kudos
Post 2 of 3
Re: How to get all MLeaders, even in Blocks nested ones?
08-13-2013 10:32 PM in reply to: anikakramer2006
You can also find your answers @ TheSwamp
Active Contributor
0 Kudos
Post 3 of 3
08-13-2013 10:49 PM in reply to: jeff
Good Morning,
wow, with an blink of an eye...
it worked perfect!
The only thing I had to add on the end of the transaction was:
Application.DocumentManager.MdiActiveDocument.Editor.Regen();
so the frames of the MLeaders are all gone.
Thank you so much!
This example will also help me for other selections.
Big help! :smileysurprised:)
Have a nice day,
Anika
