.NET
.NET
0 Kudos
Post 1 of 3
How to get AcadBlock and AcadEntity in transaction?
636 Views, 2 Replies
10-24-2011 04:56 AM
Welcome
I have a little problem - how to get AcadBlock or AcadEntities by using transaction.
In a current open document I can do something like this:
Dim document As Document = Application.DocumentManager.MdiActiveDocument
        Dim AcadDrawing As AcadDocument = DirectCast(document.AcadDocument, AcadDocument)
        For Each block As AcadBlock In AcadDrawing.Blocks
            For Each ent As AcadEntity In block
                'here I can access all of the entities in block
            Next
        Next
It's working fine, but when I tried open a document in backgroud I can't get the AcadBlock or AcadEntities, only a BlockTableRecord.
Dim path As String = "c:\path to dwg file"
        Dim db As Database = New Database(TrueTrue)
        db.ReadDwgFile(path, FileOpenMode.OpenForReadAndAllShare, TrueNothing)
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Dim blockTable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
        For Each blockRecordId As ObjectId In blockTable
            Dim blockRecord As BlockTableRecord = DirectCast(tr.GetObject(blockRecordId, OpenMode.ForRead), BlockTableRecord)'I can't get AcadEntity or AcadBlock here :/
        Next
Is there any posibility to get AcadBlocks or AcadEntities by using TransactionManager?
what's the difference between AcadBlock and BlockTableRecord?
I will be very grateful if anyone would like to help me with this problem :smileyhappy:
am I right that you try to scan through all Blocks?
Look at this code. ... does it help?
Dim blockTable As BlockTable = ctype(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
if (blockRecordID.isValid) andalso (not blockRecordID.isErased) Then
'now we can get the BlockTableRecord for this ID
Dim blockRecord As BlockTableRecord = cType(tr.GetObject(blockRecordId, OpenMode.ForRead), BlockTableRecord)
'now scan through the entities in the BlockTableRecord
for each EntID as ObjectID in blockRecord
if (EntID.isValid) andalso (not EntID.isErased) Then
dim tEnt as Entity = cType(tr.GetObject(EntID,OpenMode.ForRead),Entity)
'whatever you want to do with this Entity now ...
end if
Next
end if
Next
 HTH, - alfred -
1,218 Kudos
Post 2 of 3
Re: How to get AcadBlock and AcadEntity in transaction?
10-24-2011 05:18 AM in reply to: lukasz.taraszka
      end if
    Next
  end if
Next
 HTH, - alfred -
Alfred NESWADBA
0 Kudos
Post 3 of 3
10-24-2011 05:25 AM in reply to: Alfred.NESWADBA
That's correct - Your code is doing exactly what I meant.
Thanks for Your help and support.
Best regards
