.NET
.NET
Valued Contributor
e.g.
Message 1 of 3 (269 Views)
How to force reload linetypes from acad.lin
269 Views, 2 Replies
10-04-2011 07:32 PM
Hi, I have a bunch of drawings for which I have to reload the linetypes (they have to be redefined, for example pneumatic line has a new definition but the drawing has an older one). Is there a way other than rename the old linetypes, then load the newer version, then iterate through all objects and change the linetype to the newer version?
e.g.
Moderator
Alexander.Rivilis
Message 2 of 3 (260 Views)
Re: How to force reload linetypes from acad.lin
10-04-2011 10:12 PM in reply to: e.g.
You can use Database.LoadLineTypeFile method to load/reload linetypes and then Editor.Regen
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
e.g.
Message 3 of 3 (241 Views)
10-05-2011 08:14 AM in reply to: e.g.
Thank you very much.
e.g.
