.NET
How to force graphics update on a dimension?
6 REPLIES 6
sylvesp
721 Views, 6 Replies
Could somebody please tell me how to force a graphics update, using the .net api, on a Dimension object after changing one of it's properties?
After I change the object the graphics on the screen does not update although the property palette shows for the "Dim line color" property the value I've just assigned "Red"
The dim line on the screen shows still as green though 😞
If I move the object using the Acad command line "move"command then he dimension will be updated properly.
using (Transaction trans = acadDoc.TransactionManager.StartTransaction())
Dimension dimObject = trans.GetObject(objId, OpenMode.ForWrite) as Dimension;
dimObject.Dimclrd = Color.FromColorIndex(ColorMethod.ByAci, 1);
dimObject.dimObject.RecordGraphicsModified(true);
trans.Commit();
Seemeingly none of the "vodoo" below will help 😞
dimObject.Draw()
acadDoc.TransactionManager.QueueForGraphicsFlush();
acadDoc.TransactionManager.FlushGraphics();
AcadApp.UpdateScreen();
Peter
6 REPLIES 6
in reply to: sylvesp
You didn't post the code showing how you used the 'voodoo' that doesn't
help.
Also, is your code running from a registered command method or from the
application context?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6269057@discussion.autodesk.com...
Dimension;
trans.Commit();
dimObject.Draw()
Peter
sylvesp
Ah! That is a good point.
I did check it out and the dimension updates properly if I am running this code in a command context.
In my application though this code is located in a Standards Checker extension plugin, and it is invoked only when the user will start the manual standards checking and then he clicks the "FIX" button.
So... the context is:
- There is a command started: CheckStandards
- That commond will invoke my standards checker plugin through COM
- In this this module I get the .Net wrappers of the document and the Dimension I have to change and then modify the object using the .Net wrapper.
As a result it seems that the object properties do change but no matter how hard I try I cannot get the object graphics updated
It would be nice to have some way to force the graphics update in this case.
Based on what you say below, your COM component is
using the .NET api, which means that it is getting loaded
into AutoCAD's process.
If that's the case, then derive your standards checker plugin
class from System.EnterpriseServices.ServicedComponent,
and see if that changes anything.
wrote in message news:6269305@discussion.autodesk.com...
wrapper.
sylvesp
Unfortunately that did not help (System.EnterpriseServices.ServicedComponent).
Seems though that I've found a workaround.
After updating some properties (which not available through the com api) using the .NET api I did return to the COM API of the object and
"re-assigned" the same style name as the one the object already had. (we are talking about a dimension object)
This did force a graphic update.
It would be nice though if I could do this without having to "return" to the COM api.
Did you try calling RecomputeDimensionBlock() ?
wrote in message news:6269314@discussion.autodesk.com...
COM api.
iwx007
RecomputeDimensionBlock works!Solved years of trouble
”Boost
