.NET
.NET
Valued Contributor
swaywood
Message 1 of 11 (307 Views)
Accepted Solution
how to find the blockrefercen in a rectangle area which bound by to point?
307 Views, 10 Replies
03-14-2014 08:35 AM
is there any method without looking throgh all the blockrenferences?
Try this code
 <CommandMethod("CSW")> _
Public Sub TestSelectWindow()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
'' dummy object types for test:
Dim objects() As String = New String() {"INSERT", "LINE", "LWPOLYLINE", "CIRCLE"}
'' dummy layers for test:
Dim layers() As String = New String() {"DIM", "DWGRU", "ANNO-TLB", "Defpoints"}
Dim layerfilt As String = String.Join(",", layers)
Dim objfilt As String = String.Join(",", objects)
'' Create a TypedValue array to define the filter by object types (dxf code 0) and layers (dxf code 8)
Dim tvs() As TypedValue = New TypedValue() {New TypedValue(0, objfilt), New TypedValue(8, layerfilt)}
'' Assign the filter criteria to a SelectionFilter object
Dim filter As SelectionFilter = New SelectionFilter(tvs)
Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "Specify lower legt corner of window: ")
Dim pres As PromptPointResult = ed.GetPoint(ppo)
If pres.Status <> PromptStatus.OK Then Return
Dim p1 As Point3d = pres.Value
Dim pco As PromptCornerOptions = New PromptCornerOptions(vbLf & "Opposite corner point: ", p1)
pres = ed.GetCorner(pco)
Dim p2 As Point3d = pres.Value
'' Request for objects to be selected in the drawing area
Dim res As PromptSelectionResult
res = ed.SelectCrossingWindow(p1, p2, filter)
'' If the prompt status is OK, objects were selected
'If res.Status = PromptStatus.OK Then
Dim sset As SelectionSet = res.Value
If sset.Count > 0 Then
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Number of objects selected: " & sset.Count.ToString)
Else
Return
Using tr As Transaction = db.TransactionManager.StartTransaction()
Try
For Each sobj As SelectedObject In sset
Dim ent As Entity = DirectCast(tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False), Entity)
Dim blk As BlockReference = TryCast(ent, BlockReference)
If blk IsNot Nothing Then
ed.WriteMessage(vbLf & "Block Name: {0}", blk.Name)
Dim circ As Circle = TryCast(ent, Circle)
If circ IsNot Nothing Then
ed.WriteMessage(vbLf & "Radius: {0}", circ.Radius.ToString())
Dim pline As Polyline = TryCast(ent, Polyline)
If pline IsNot Nothing Then
ed.WriteMessage(vbLf & "Number Of Vertices: {0}", pline.NumberOfVertices.ToString())
Dim ln As Line = TryCast(ent, Line)
If ln IsNot Nothing Then
ed.WriteMessage(vbLf & "Start Point: {0}", ln.StartPoint.ToString())
Next
tr.Commit()
Catch ex As System.Exception
ed.WriteMessage(ex.StackTrace & vbLf & ex.StackTrace)
End Try
End Using
End Sub
mzakiralam
Message 2 of 11 (303 Views)
Re: how to find the blockrefercen in a rectangle area which bound by to point?
03-14-2014 08:43 AM in reply to: swaywood
Can you clear Little bit more regarding your Problem? you can also your Screen shot.
*Expert Elite*
Hallex
Message 3 of 11 (289 Views)
03-14-2014 10:19 AM in reply to: swaywood
Try this code
            Else
                Return
                Try
                    Next
                    tr.Commit()
                End Try
            End Using
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Valued Contributor
swaywood
Message 4 of 11 (262 Views)
03-14-2014 11:48 PM in reply to: mzakiralam
hi,mzakiralam,
i lost two letters, 'by to point' shall be 'by two points', sorry for that.
best regards
swaywood
Valued Contributor
swaywood
Message 5 of 11 (262 Views)
03-14-2014 11:50 PM in reply to: Hallex
hi, Hallex,
thank you for your reply, your method is correct, but i want to find another method which will use LINQ.
*Expert Elite*
Hallex
Message 6 of 11 (253 Views)
03-15-2014 01:37 AM in reply to: swaywood
Better yet show us you code you're started with,
or upload the image to make a sense
*Expert Elite*
_gile
Message 7 of 11 (235 Views)
03-16-2014 03:47 AM in reply to: swaywood
I'm not sure to understand what you mean with "using Linq".
If you meant using Linq to avoid using a selection set (e.g. using from a side database), her's an example:
Query syntax:
        private ObjectId[] FindBlockReferencesInRectangle(Point3d pt1, Point3d pt2, Database db)
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
            using (Line line = new Line(pt1, pt2))
                Extents3d bound = line.GeometricExtents;
                BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(
                  SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                Func<ObjectId, bool> isBlockReference = (id =>
                    id.ObjectClass == RXClass.GetClass(typeof(BlockReference)));
                Func<ObjectId, bool> isInside = (id =>
                    BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                    Extents3d exts = new Extents3d(bound.MinPoint, bound.MaxPoint);
                    exts.AddExtents(br.GeometricExtents);
                    return bound.IsEqualTo(exts);
                var blocks =
                    from ObjectId id in modelSpace
                    where isBlockReference(id) && isInside(id)
                    select id;
                return blocks.ToArray();
Extension methods syntax:
                return modelSpace
                    .Cast<ObjectId>()
                    .Where(isBlockReference)
                    .Where(isInside)
                    .ToArray();
Gilles Chanteau
Valued Contributor
swaywood
Message 8 of 11 (226 Views)
03-16-2014 07:39 AM in reply to: _gile
hi,giles,
that's exactly what i expect, thank you so much.
regards
swaywood
*Expert Elite*
_gile
Message 9 of 11 (197 Views)
03-17-2014 02:47 AM in reply to: swaywood
Hi swaywood,
I'm glad it helps.
I also like the functional style available with Linq for the .NET "historic" languages (VB and C#), it is the "natural" way of coding with F#:
let findBlocksInRectangle pt1 pt2 (db : Database) =
    use tr = db.TransactionManager.StartOpenCloseTransaction()
    use line = new Line(pt1, pt2)
    let bound = line.GeometricExtents
    let rxc = RXClass.GetClass(typeof<BlockReference>)
    let isBlock (id : ObjectId) =  id.ObjectClass = rxc
    let isInside (id : ObjectId) =
        let br = tr.GetObject(id, OpenMode.ForRead) :?> BlockReference
        let exts = new Extents3d(bound.MinPoint, bound.MaxPoint)
        exts.IsEqualTo(bound)
    (tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead)
    :?> BlockTableRecord)
    |> Seq.cast<ObjectId>
    |> Seq.filter isBlock
    |> Seq.filter isInside
    |> Seq.toArray
Anyway all these functions do scan the whole model space entities to get all the block references and filter those which are inside the rectangle.
They are all absolutely equivalent to the following one written in a classic imperative style:
            return QueryForBlocksInRectangle(pt1, pt2, db).ToArray();
        private IEnumerable<ObjectId> QueryForBlocksInRectangle(Point3d pt1, Point3d pt2, Database db)
                RXClass brClass = RXClass.GetClass(typeof(BlockReference));
                foreach (ObjectId id in modelSpace)
                    if (id.ObjectClass == brClass)
                        if (bound.IsEqualTo(exts))
                            yield return id;
Gilles Chanteau
Valued Contributor
swaywood
Message 10 of 11 (158 Views)
03-18-2014 01:04 AM in reply to: _gile
Hi,Gilles:
I am not familiar with F#.
I think linq is more efficient to find the result. I will have a try.
Thanks again
swaywood
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
