.NET
How to find Layout is empty or not?
3 REPLIES 3
737 Views, 3 Replies
Is it possible to distinguish whether a Layout is empty or not?
I need to check this routine in plenty of drawing, so please tell me some easy way to find empty layout.
Thanks in advance,
thenndral
3 REPLIES 3
Ajilal.Vijayan
You may need iterate through the BlockTableRecord of each layout to find whether it contains any objects.
_gile
in reply to: Ajilal.Vijayan
Keep in mind an empty Layout BlockTableRecord anayway contains a Viewport (the layout viewport, cvport = 1).
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Thanks _gile for an awesome code.
May be this code will helpful for someone.
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var layouts = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (var entry in layouts)
                    var layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
                    var btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead);
                    ed.WriteMessage("\n{0} contains {1} ObjectId.", layout.LayoutName, btr.Cast<ObjectId>().Count());
                tr.Commit();
Thanks again,
thenndral
”Boost
