.NET
.NET
Active Member
0 Kudos
Post 1 of 9
How to extrude imported dxf along polyline?
637 Views, 8 Replies
10-21-2012 05:34 PM
I have region is in external dxf file,
how to extrude it along polyline?
I can't get region after using dxfin method
                    Database myDxfDb = new Database(false, true);
                    myDxfDb.DxfIn(filename, logFilename);
                    Matrix3d dxfTrf = Matrix3d.Identity;
                    _ThisDatabase.Insert(dxfTrf, myDxfDb, true);
                    _ThisDatabase.UpdateExt(true);
                    myDxfDb.Dispose();
                    acTrans.Commit();
                    ObjectId id = AcUtils.EntLast();
                    Entity _ent = (Entity)acTrans.GetObject(id, OpenMode.ForWrite);
1,219 Kudos
Post 2 of 9
Re: How to extrude imported dxf along polyline?
10-21-2012 05:41 PM in reply to: awdas
look to the objecttype that is the result of inserting the DXF ==> is it a region or is it a block(definition/-reference....) :smileywink:
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 3 of 9
10-21-2012 05:46 PM in reply to: Alfred.NESWADBA
dxf file contain only one region object
1,219 Kudos
Post 4 of 9
10-21-2012 05:51 PM in reply to: awdas
and now try to insert this DXF into another drawing ==> what does it get then?
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 5 of 9
10-21-2012 05:57 PM in reply to: Alfred.NESWADBA
Hi alfred,
yes, I can that. dxf import as block reference.
well, how can I use this block reference :smileyhappy:
1,219 Kudos
Post 6 of 9
10-21-2012 06:04 PM in reply to: awdas
either explode it or use the BlockTableRecord from this object to get the parts of this blockdefinition, there you also find then the region. You can then create an extrusion if this and add it to the database.
Good luck, -  alfred -
Alfred NESWADBA
1,219 Kudos
Post 7 of 9
10-21-2012 06:09 PM in reply to: awdas
and a sample for how to create 3D-solids from 2D-objects could be found >>>here<<< (and Kean Walmsley has a lot more interesting samples on his site)
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 8 of 9
10-21-2012 07:16 PM in reply to: Alfred.NESWADBA
thanks a lot for your interrest alfred,
but my problem is not extrude region. I cant get region from dxf file.
Active Member
0 Kudos
Post 9 of 9
10-21-2012 10:10 PM in reply to: awdas
I found the solution
        public Entity ImportDxfAsEntity(string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            Entity ent = null;
            using (Database bdb = new Database(false, true))
                bdb.DxfIn(FileName, @"c:\log.txt");
                //blkid = _ThisDatabase.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                blkid = _ThisDatabase.Insert("blok", bdb, true);
                using (Transaction tr = _ThisDatabase.TransactionManager.StartTransaction())
                    BlockReference bref = new BlockReference(InsertionPoint, blkid);
                    using (BlockTableRecord btAttRec = (BlockTableRecord)bref.BlockTableRecord.GetObject(OpenMode.ForWrite))
                        foreach (ObjectId subid in btAttRec)
                            ent = (Entity)subid.GetObject(OpenMode.ForRead);
                    tr.Commit();
            return ent;
