>> I've just begun programming AutoCAD using .Net.
Right. And .NET is not VBA, and you shouldn't try to
use it like it was.
In this case, that means you don't use SendStringToExecute()
to send commands to AutoCAD, you write the code that will
create the objects you're trying to create using the API, and
not by executing commands.
Think of .NET as a very steep hill, which you are nearly at
the bottom of. Spend some time becoming familiar with
.NET and the AutoCAD .NET API, rather than just trying to
'port' VBA code that relies on kludges to get things done.
If you must execute commands, there's a better way to do
that in .NET, which has none of the problems that plague
SendStringToExecute().
Have a look here:
http://www.caddzone.com/CommandLine.vb
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5725447@discussion.autodesk.com...
I've just begun programming AutoCAD using .Net. Maybe answer to my question is trivial, but I can't figured out how to execute for eg. lisp command during executing other .net command.
After I add circle with SendStringToExecute there is no new circle in model space until the overriding "command1" command finishes.
My example code:
Public Class cadxClass
' Define command 'Asdkcmd1'
_
Public Sub Asdkcmd1()
Module1.aaa()
End Sub
End Class
Public Sub aaa()
Dim acadApp As Autodesk.AutoCAD.Interop.AcadApplication
Dim aDoc As Autodesk.AutoCAD.Interop.AcadDocument
Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Application.DocumentManager.MdiActiveDocument.Editor
acadApp = CType(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
acadApp.Visible = True
aDoc = acadApp.ActiveDocument
Dim p1(2) As Double
p1(0) = 10
p1(1) = 10
p1(2) = 0
aDoc.ModelSpace.AddCircle(p1, 100)
MsgBox(aDoc.ModelSpace.Count.ToString)
Dim d As Autodesk.AutoCAD.ApplicationServices.Document
d = Application.DocumentManager.MdiActiveDocument
d.SendStringToExecute("_Circle" & vbCr & "30,30,0" & vbCr & "4" & vbCr, False, False, True)
End Sub
