.NET
How To Edit The Entities Of A Block
2 REPLIES 2
NEP_perpetual
357 Views, 2 Replies
I've been searching and searching but I can't figure out how to do this.
My goal is to modify the actual entities that make up a block.  Is this possible?
So far all that I've discovered is how to get a block's Block Table Record and add things to it.
Dim btr As BlockTableRecord = m.Trx.GetObject(m.BlkTbl("The Name Of The Block"), OpenMode.ForWrite)
How can I get a list of entities in the block and edit them?
2 REPLIES 2
Try this.
This code will change the actual text content inside a block
http://www.acadnetwork.com/index.php?topic=313.0
Thanks!  I didn't expect it to be so easy!
”Boost
