I've been searching and searching but I can't figure out how to do this.
My goal is to modify the actual entities that make up a block. Is this possible?
So far all that I've discovered is how to get a block's Block Table Record and add things to it.
Dim btr As BlockTableRecord = m.Trx.GetObject(m.BlkTbl("The Name Of The Block"), OpenMode.ForWrite)
How can I get a list of entities in the block and edit them?
Solved by Ajilal.Vijayan. Go to Solution.
Try this.
This code will change the actual text content inside a block
