.NET
How to edit a .dwg file without opening AutoCAD
8 REPLIES 8
Message 1 of 9
adjg13
22111 Views, 8 Replies
Hello All,
Is there a way to edit a .dwg file (specifically I want to gather entities based on their layer and then change them to a different layer) without opening the AutoCAD?
I guess I'm looking for some sort of way to open the file without all the graphics. I just want to access and edit the data.
I have a large amount of files that need to be processed and it would just take forever. I was hoping there was some way to open the drawing in the background for the program to work with.
8 REPLIES 8
Message 2 of 9
arcticad
in reply to: adjg13
You can open the drawing as a side database, (Autocad needs to be running, No Additional Cost).
Or you can use RealDWG to open it (Without Autocad Running, Cost Money)
(defun botsbuildbots() (botsbuildbots))
Message 3 of 9
in reply to: adjg13
I think this is not possible to edit a .dwg file without opening AutoCAD
Message 4 of 9
adjg13
Thank you articad. I searched how to open a .dwg as a side database and I found an article on through the interface that gives some good examples. Here it is in case anyone else runs across this topic.
http://through-the-interface.typepad.com/through_the_interface/2007/07/accessing-dwg-f.html
Message 5 of 9
dgorsman
in reply to: adjg13
There is also the core console for simple GUI-less operations.
Message 6 of 9
arcticad
in reply to: dgorsman
Message 7 of 9
27925916
in reply to: arcticad
hi,have you completed reading data from dwg without openning cad? I am also working on it recently.
Message 8 of 9
in reply to: adjg13
Its not working in Autocad 2017. Anyone have solved it for the new Autocad?
Its error :
Error BC31091 Import of type 'IDynamicMetaObjectProvider' from assembly or module 'System.Core.dll' failed. PLTUL2 E:\Documents\Dropbox\Public\VB.Net\PLTUL\PLTUL2\Class1.vb 831 Active
Message 9 of 9
tlagendyk
in reply to: adjg13
Autocad has a built in feature called core console, you can use it with windows batch filing scripts to modify many files without opening them https://github.com/albisserAdrian/acadCC
”Boost
