.NET
.NET
Active Contributor
adjg13
Message 1 of 6 (1,483 Views)
How to edit a .dwg file without opening AutoCAD
1483 Views, 5 Replies
08-21-2013 07:28 AM
Hello All,
Is there a way to edit a .dwg file (specifically I want to gather entities based on their layer and then change them to a different layer) without opening the AutoCAD?
I guess I'm looking for some sort of way to open the file without all the graphics. I just want to access and edit the data.
I have a large amount of files that need to be processed and it would just take forever. I was hoping there was some way to open the drawing in the background for the program to work with.
arcticad
Message 2 of 6 (1,478 Views)
Re: How to edit a .dwg file without opening AutoCAD
08-21-2013 07:33 AM in reply to: adjg13
You can open the drawing as a side database, (Autocad needs to be running, No Additional Cost).
Or you can use RealDWG to open it (Without Autocad Running, Cost Money)
(defun botsbuildbots() (botsbuildbots))
mzakiralam
Message 3 of 6 (1,477 Views)
I think this is not possible to edit a .dwg file without opening AutoCAD
Active Contributor
adjg13
Message 4 of 6 (1,470 Views)
08-21-2013 07:38 AM in reply to: mzakiralam
Thank you articad. I searched how to open a .dwg as a side database and I found an article on through the interface that gives some good examples. Here it is in case anyone else runs across this topic.
http://through-the-interface.typepad.com/through_the_interface/2007/07/accessing-dwg-f.html
dgorsman
Message 5 of 6 (1,451 Views)
08-21-2013 08:37 AM in reply to: adjg13
There is also the core console for simple GUI-less operations.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
arcticad
Message 6 of 6 (1,446 Views)
08-21-2013 08:52 AM in reply to: dgorsman
