.NET
how to drawing a line tangent to two circles in C#?
8 REPLIES 8
Message 1 of 9
ydsoo8
6456 Views, 8 Replies
8 REPLIES 8
Message 2 of 9
_gile
in reply to: ydsoo8
Message 3 of 9
dgorsman
in reply to: ydsoo8
Break out the math (all that work in high school you never thought would be useful... who knew).  A line that is tangent to a circle will be at 90 degrees to the radius of that circle.  For a line to be tangent to two circles, you need to find a line that is perpendicular to the radius of each circle.  Under this cirumstance, the radii of both circles will be parallel.  From there its just a matter of having a line extending from each circles center to its respective radius, using the same angle for each, and the tangent line will connect them.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 9
ydsoo8
in reply to: dgorsman
我的意思是想用C#实现
LINE <enter>
TAN <enter>
Pick the first point
TAN <enter>
Pick the second point
<enter>
这样的一个功能,而不是将两圆的所有公切线都画出来,仅画出自已所需的一条公切线。
本人初学对autocad一些函数用法不熟悉。希望老师用C#代码将上述命令模拟出来。
本人英语水水很菜,只能写中文了
Message 5 of 9
_gile
in reply to: ydsoo8
Here's an extension method for the CicularArc3d class.
It returns a List of LineSegment3d for the tangents between two circles (maybe 0, 2 or 4).
An exception is thrown if the circles do not lie on the same plane.
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace TangentsToCircle
    public static class Tangents
        public static List<LineSegment3d> GetTangentsToCircle(this CircularArc3d circle, CircularArc3d other)
            // check if circles lies on the same plane
            Vector3d normal = circle.Normal;
            Plane plane = new Plane(Point3d.Origin, normal);
            double elev1 = circle.Center.TransformBy(Matrix3d.WorldToPlane(plane)).Z;
            double elev2 = other.Center.TransformBy(Matrix3d.WorldToPlane(plane)).Z;
            if (!(normal.IsParallelTo(other.Normal) &&
                Math.Abs(elev1 - elev2) < Tolerance.Global.EqualPoint))
                throw new Autodesk.AutoCAD.Runtime.Exception(
                    Autodesk.AutoCAD.Runtime.ErrorStatus.NonCoplanarGeometry);
            List<LineSegment3d> result = new List<LineSegment3d>();
            // check if a circle is not inside the other
            double dist = circle.Center.DistanceTo(other.Center);
            if (dist <= Math.Abs(circle.Radius - other.Radius))
                return result;
            CircularArc3d tmp1, tmp2;
            Point3d center;
            Point3d[] inters;
            Vector3d vec, vec1, vec2;
            // external tangents
            if (circle.Radius == other.Radius)
                center = circle.Center;
                vec = other.Center - center;
                Line3d perp = new Line3d(center, vec.CrossProduct(normal));
                inters = circle.IntersectWith(perp);
                if (inters != null)
                    result.Add(new LineSegment3d(inters[0], inters[0] + vec));
                    result.Add(new LineSegment3d(inters[1], inters[1] + vec));
            else
                if (circle.Radius < other.Radius)
                    tmp1 = circle;
                    circle = other;
                    other = tmp1;
                tmp1 = new CircularArc3d(circle.Center, normal, circle.Radius - other.Radius);
                tmp2 = new CircularArc3d(center + vec / 2.0, normal, dist / 2.0);
                inters = tmp1.IntersectWith(tmp2);
                if (inters != null)
                    vec1 = (inters[0] - center).GetNormal();
                    vec2 = (inters[1] - center).GetNormal();
                    result.Add(new LineSegment3d(center + vec1 * circle.Radius, other.Center + vec1 * other.Radius));
                    result.Add(new LineSegment3d(center + vec2 * circle.Radius, other.Center + vec2 * other.Radius));
            // crossing tangents
            if (circle.Radius + other.Radius < dist)
                double ratio = (circle.Radius / (circle.Radius + other.Radius)) / 2.0;
                tmp1 = new CircularArc3d(center + vec * ratio, normal, dist * ratio);
                inters = circle.IntersectWith(tmp1);
                if (inters != null)
                    result.Add(new LineSegment3d(center + vec1 * circle.Radius, other.Center + vec1.Negate() * other.Radius));
                    result.Add(new LineSegment3d(center + vec2 * circle.Radius, other.Center + vec2.Negate() * other.Radius));
            return result;
A test command:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(TangentsToCircle.CommandMethods))]
    public class CommandMethods
        [CommandMethod("Test", CommandFlags.Modal)]
        public void Test()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a circle: ");
            peo.SetRejectMessage("Only a circle.");
            peo.AddAllowedClass(typeof(Circle), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            ObjectId id1 = per.ObjectId;
            peo.Message = "\nSelect another circle: ";
            ObjectId id2;
            while (true)
                    return;
                id2 = per.ObjectId;
                if (id1 == id2)
                    ed.WriteMessage("\nThe second circle is the same as the first one.");
                else break;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Circle c1 = (Circle)tr.GetObject(id1, OpenMode.ForRead);
                    Circle c2 = (Circle)tr.GetObject(id2, OpenMode.ForRead);
                    CircularArc3d ca1 = new CircularArc3d(c1.Center, c1.Normal, c1.Radius);
                    CircularArc3d ca2 = new CircularArc3d(c2.Center, c2.Normal, c2.Radius);
                    List<LineSegment3d> lines = ca1.GetTangentsToCircle(ca2);
                    BlockTableRecord btr =
                        (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    foreach (LineSegment3d l in lines)
                        Line line = new Line(l.StartPoint, l.EndPoint);
                        btr.AppendEntity(line);
                        tr.AddNewlyCreatedDBObject(line, true);
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception exn)
                ed.WriteMessage("\n" + exn.Message);
            catch (System.Exception exn)
Gilles Chanteau
GileCAD
GitHub
Message 6 of 9
_gile
in reply to: _gile
A better (more robust and xml documented) implementation.
using System;
namespace GeometryExtensions
    /// <summary>
    /// Tangent type enum
    /// </summary>
    [Flags]
    public enum TangentType { Inner = 1, Outer = 2 }
    /// <summary>
    /// Provides extension methods for the CircularArc3d class.
    /// </summary>
    public static class CircularArc3dExtensions
        /// <summary>
        /// Returns the tangents between the active CircularArc3d instance complete circle and another one.
        /// </summary>
        /// <remarks>
        /// Tangents start points are on the object to which this method applies, end points on the one passed as argument.
        /// Tangents are always returned in the same order: outer tangents before inner tangents, and for both,
        /// the tangent on the left side of the line from this circular arc center to the other one before the one on the right side.
        /// </remarks>
        /// <param name="arc">The object to which this method applies.</param>
        /// <param name="other">The CircularArc3d to which searched for tangents.</param>
        /// <param name="flags">An enum value specifying which type of tangent is returned.</param>
        /// <returns>An array of LineSegment3d representing the tangents (maybe 2 or 4) or null if there is none.</returns>
        /// <exception cref="Autodesk.AutoCAD.Runtime.exception">eNonCoplanarGeometry is thrown if the objects do not lies on theme plane.</exception>
        public static LineSegment3d[] GetTangentsTo(this CircularArc3d arc, CircularArc3d other, TangentType flags)
            Vector3d normal = arc.Normal;
            double elev1 = arc.Center.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
            double elev2 = other.Center.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
            // check if a circle is inside the other
            double dist = arc.Center.DistanceTo(other.Center);
            if (dist - Math.Abs(arc.Radius - other.Radius) <= Tolerance.Global.EqualPoint)
                return null;
            // check if circles overlap
            bool overlap = arc.Radius + other.Radius >= dist;
            if (overlap && flags == TangentType.Inner)
                return null;
            Point3d[] inters;
            Vector3d vec1, vec2, vec = other.Center - arc.Center;
            int i, j;
            LineSegment3d[] result = new LineSegment3d[(int)flags == 3 && !overlap ? 4 : 2];
            // outer tangents
            if (flags.HasFlag(TangentType.Outer))
                if (arc.Radius == other.Radius)
                    Line3d perp = new Line3d(arc.Center, vec.CrossProduct(normal));
                    inters = arc.IntersectWith(perp);
                    vec1 = (inters[0] - arc.Center).GetNormal();
                    vec2 = (inters[1] - arc.Center).GetNormal();
                    i = vec.GetAngleTo(vec1, normal) < vec.GetAngleTo(vec2, normal) ? 0 : 1;
                    j = i ^ 1;
                    result[i] = new LineSegment3d(inters[0], inters[0] + vec);
                    result[j] = new LineSegment3d(inters[1], inters[1] + vec);
                else
                    Point3d center = arc.Radius < other.Radius ? other.Center : arc.Center;
                    tmp1 = new CircularArc3d(center, normal, Math.Abs(arc.Radius - other.Radius));
                    tmp2 = new CircularArc3d(arc.Center + vec / 2.0, normal, dist / 2.0);
                    j = i ^ 1;
                    result[i] = new LineSegment3d(arc.Center + vec1 * arc.Radius, other.Center + vec1 * other.Radius);
                    result[j] = new LineSegment3d(arc.Center + vec2 * arc.Radius, other.Center + vec2 * other.Radius);
            // inner tangents
            if (flags.HasFlag(TangentType.Inner) && !overlap)
                double ratio = (arc.Radius / (arc.Radius + other.Radius)) / 2.0;
                tmp1 = new CircularArc3d(arc.Center + vec * ratio, normal, dist * ratio);
                inters = arc.IntersectWith(tmp1);
                i = vec.GetAngleTo(vec1, normal) < vec.GetAngleTo(vec2, normal) ? 2 : 3;
                j = i == 2 ? 3 : 2;
                result[i] = new LineSegment3d(arc.Center + vec1 * arc.Radius, other.Center + vec1.Negate() * other.Radius);
                result[j] = new LineSegment3d(arc.Center + vec2 * arc.Radius, other.Center + vec2.Negate() * other.Radius);
            return result;
        /// <summary>
        /// Returns the tangents between the active CircularArc3d instance complete circle and a point.
        /// </summary>
        /// <remarks>
        /// Tangents start points are on the object to which this method applies, end points on the point passed as argument.
        /// Tangents are always returned in the same order: the tangent on the left side of the line from the circular arc center
        /// to the point before the one on the right side.
        /// </remarks>
        /// <param name="pt">The Point3d to which tangents are searched</param>
        /// <returns>An array of LineSegement3d representing the tangents (2) or null if there is none.</returns>
        public static LineSegment3d[] GetTangentsTo(this CircularArc3d arc, Point3d pt)
            // check if circle and point lies on the plane
            double elev2 = pt.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
            if (Math.Abs(elev1 - elev2) < Tolerance.Global.EqualPoint)
            // check if the point is inside the circle
            Point3d center = arc.Center;
            if (pt.DistanceTo(center) <= arc.Radius)
                return null;
            Vector3d vec = pt.GetVectorTo(center) / 2.0;
            CircularArc3d tmp = new CircularArc3d(pt + vec, arc.Normal, vec.Length);
            Point3d[] inters = arc.IntersectWith(tmp);
            LineSegment3d[] result = new LineSegment3d[2];
            int i = vec.GetAngleTo(inters[0] - center, normal) < vec.GetAngleTo(inters[1] - center, normal) ? 0 : 1;
            int j = i ^ 1;
            result[i] = new LineSegment3d(inters[0], pt);
            result[j] = new LineSegment3d(inters[1], pt);
            return result;
A test command which draws a closed polyline  along the outer tangents and the trimmed selected circles.
        [CommandMethod("JoinCircles", CommandFlags.Modal)]
        public void JoinCircles()
                return;
            ObjectId id2;
            while (true)
                    return;
                id2 = per.ObjectId;
                if (id1 == id2)
                else break;
            try
                    LineSegment3d[] lines = ca1.GetTangentsTo(ca2, TangentType.Outer);
                    if (lines != null)
                        Vector3d vec = c1.Center.GetVectorTo(c2.Center);
                        Plane plane = new Plane(Point3d.Origin, c1.Normal);
                        double a1 = vec.GetAngleTo(ca1.Center.GetVectorTo(lines[1].StartPoint), ca1.Normal) -
                            vec.GetAngleTo(ca1.Center.GetVectorTo(lines[0].StartPoint), ca1.Normal);
                        double a2 = vec.Negate().GetAngleTo(ca2.Center.GetVectorTo(lines[0].EndPoint), ca1.Normal) -
                            vec.Negate().GetAngleTo(ca2.Center.GetVectorTo(lines[1].EndPoint), ca1.Normal);
                        Polyline pline = new Polyline(4);
                        pline.AddVertexAt(0, lines[0].StartPoint.Convert2d(plane), Math.Tan(a1 / 4.0), 0.0, 0.0);
                        pline.AddVertexAt(1, lines[1].StartPoint.Convert2d(plane), 0.0, 0.0, 0.0);
                        pline.AddVertexAt(2, lines[1].EndPoint.Convert2d(plane), Math.Tan(a2 / 4.0), 0.0, 0.0);
                        pline.AddVertexAt(3, lines[0].EndPoint.Convert2d(plane), 0.0, 0.0, 0.0);
                        pline.Closed = true;
                        pline.Normal = c1.Normal;
                        pline.Elevation = c1.Center.TransformBy(Matrix3d.WorldToPlane(c1.Normal)).Z;
                        btr.AppendEntity(pline);
                        tr.AddNewlyCreatedDBObject(pline, true);
                        c1.UpgradeOpen();
                        c2.UpgradeOpen();
                        c1.Erase();
                        c2.Erase();
                    tr.Commit();
                ed.WriteMessage("\nError: " + exn.Message);
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
ydsoo8
in reply to: _gile
谢谢你的回复. 可能你没有理解我所表达的意思。虽然你的代码没有实现我所想要的功能,但是我可以根所据你的代码进行更改来实现。
Thank you for your reply. You may not understand what I mean. Although your code does not realize what I want, but I can change according to your code to achieve.. Then I will put out the modified code.
Message 8 of 9
ydsoo8
in reply to: _gile
struct lineDist
            public Line  l;
            public double dist;
        [CommandMethod("tt")]
        static public void test()
            Point3d pickedP1;
            Point3d pickedP2;
                return;
            pickedP1 = per.PickedPoint;
            ObjectId id2;
            while (true)
                    return;
                id2 = per.ObjectId;
                pickedP2 = per.PickedPoint;
                if (id1 == id2)
                else break;
            try
                    List<LineSegment3d> lines = ydsCommands.GetTangentsToCircle(ca1, ca2);
                    List<lineDist> ld = new List<lineDist>(lines.Count);
                    double dist = 0;
                    lineDist ldx = new lineDist();
                        dist = line.GetClosestPointTo(pickedP1, true).DistanceTo(pickedP1) + line.GetClosestPointTo(pickedP2, true).DistanceTo(pickedP2);
                        ldx.l = line;
                        ldx.dist = dist;
                        ld.Add(ldx);
                    foreach (lineDist d in ld)
                        if (d.dist < ldx.dist)
                            ldx = d;
                    btr.AppendEntity(ldx.l);
                    tr.AddNewlyCreatedDBObject(ldx.l, true);
                    tr.Commit();
         public static List<LineSegment3d> GetTangentsToCircle(CircularArc3d circle, CircularArc3d other)
                return result;
            Point3d center;
            Point3d[] inters;
                if (inters != null)
            else
                    tmp1 = circle;
                    circle = other;
                    other = tmp1;
                if (inters != null)
                if (inters != null)
            return result;
Message 9 of 9
viper_007
in reply to: ydsoo8
wow, looks a lot of work
聚傲气于一身,显傲骨之精华
”Boost
