.NET
how to Draw/create fillet using .NET ?
13 REPLIES 13
Message 1 of 14
6092 Views, 13 Replies
I created a rectangle using draw line (i am wirking on Autocad 2010)
Now I want to create 4 fillets at each corner with some radius using vb.net
Please somebody help me please
dipak Edited by: dip_nik on Jan 13, 2010 11:22 AM
13 REPLIES 13
Message 2 of 14
Hallex
This one is a bit tricky but working for mein A2008
(spell all prompts)
{code}
using System;
using System.Text;
using System.Collections;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CurveMod
public class CurveModify
[CommandMethod("FLT", CommandFlags.UsePickSet & CommandFlags.Redraw)]
static public void FilletLines()
Database db = HostApplicationServices.WorkingDatabase;
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
try
// Prompt for the fillet radius
PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter the fillet radius: ");
pdo.AllowZero = false;
pdo.AllowNegative = false;
pdo.AllowNone = false;
PromptDoubleResult pdr = ed.GetDouble(pdo);
if (pdr.Status != PromptStatus.OK)
return;
double rad = pdr.Value;
// Prompt for the lines to fillet
PromptEntityOptions peo = new PromptEntityOptions("\nSelect first line:");
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
ObjectId fid = per.ObjectId;
peo.Message = "\nSelect second line:";
return;
ObjectId sid = per.ObjectId;
// get entities
Entity ent1 = tr.GetObject(fid, OpenMode.ForRead) as Entity;
Entity ent2 = tr.GetObject(sid, OpenMode.ForRead) as Entity;
// cast entites as lines
Line line1 = ent1 as Line;
Line line2 = ent2 as Line;
Point3dCollection intpts = new Point3dCollection();
// get intersection between lines
line1.IntersectWith(line2, Intersect.OnBothOperands, intpts, 0, 0);
if (intpts.Count != 1)
acadApp.ShowAlertDialog("Lines are colinear or does not intersects");
return;
Point3d ip = intpts[0];
Point3d midp1;
Point3d midp2;
// compare points
if (!(line1.StartPoint.Equals(ip)))
line1.UpgradeOpen();
line1.EndPoint = line1.StartPoint;
line1.StartPoint = ip;
midp1 = line1.GetPointAtDist(rad);
if (!(line2.StartPoint.Equals(ip)))
line2.UpgradeOpen();
line2.EndPoint = line2.StartPoint;
line2.StartPoint = ip;
midp2 = line2.GetPointAtDist(rad);
// get point on bisector
Point3d midp = new Point3d(
(midp1.X + midp2.X) / 2.0,
(midp1.Y + midp2.Y) / 2.0,
(midp1.Z + midp2.Z) / 2.0);
// get angles along lines from intersection
double ang1 = AngleFromX(ip, midp1);
double ang2 = AngleFromX(ip, midp2);
// get bisector angle
double ang = AngleFromX(ip, midp);
// calculate angle between lines
double angc = Math.Abs(ang2 - ang1);
// get a half of them
double bis = angc / 2.0;
// calculate hypotenuse
double hyp = rad / Math.Sin(bis);
// calculate center point of filleting arc
Point3d cp = PolarPoint(ip, ang, hyp);
// calculate another leg of a triangle
double cat = Math.Sqrt((Math.Pow(hyp, 2)) - (Math.Pow(rad, 2)));
// calculate center point on arc
Point3d pa = PolarPoint(ip, ang, hyp - rad);
// calculate start point of arc
Point3d ps = PolarPoint(ip, ang1, cat);
// calculate end point of arc
Point3d pe = PolarPoint(ip, ang2, cat);
// define arc
Arc arc = new Arc();
// check on direction of points
if (isLeft(midp2, ip, midp1))
arc = new Arc(cp, rad, AngleFromX(cp, pe), AngleFromX(cp, ps));
else
arc = new Arc(cp, rad, AngleFromX(cp, ps), AngleFromX(cp, pe));
// trim lines by arc
line1.StartPoint = ps;
line2.StartPoint = pe;
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
// add arc to space
btr.AppendEntity(arc);
tr.AddNewlyCreatedDBObject(arc, true);
tr.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
acadApp.ShowAlertDialog(ex.Message);
}//dispose transaction
/// Polar point // credit to Tony Tanzillo
public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
return new Point3d(
basepoint.X + (distance * Math.Cos(angle)),
basepoint.Y + (distance * Math.Sin(angle)),
basepoint.Z);
public static double AngleFromX(Point3d pt1, Point3d pt2)
Plane ucsplane = new Plane(new Point3d(0, 0, 0), new Vector3d(0, 0, 1));
Vector3d vec = pt2 - pt1;
double ang = vec.AngleOnPlane(ucsplane);
return ang;
/// isleft function (edited) // credit to Bryco
public static bool isLeft(Point3d spt, Point3d ept, Point3d apt)
bool result = false;
double Ans = ((ept.X - spt.X) * (apt.Y - spt.Y) -
(apt.X - spt.X) * (ept.Y - spt.Y));
if (Ans > 0)
result = true;
else
result = false;
return result;
{code}
~'J'~
Message 3 of 14
Hi hallex ,
Thanks a lottttttttt
for the reply.
Have a nice Day
Message 4 of 14
Hallex
Glad to help
Cheers 🙂
~'J'~
Message 5 of 14
cean_au
is there a vb.net version?
thx
Message 6 of 14
Balaji_Ram
in reply to: cean_au
Here is a link that I personally find useful in converting code from C# to VB.Net and vice-versa.
Some basic things will need to be fixed if you get some compile errors.
http://www.developerfusion.com/tools/convert/csharp-to-vb/
Balaji
Developer Technical Services
Autodesk Developer Network
Message 7 of 14
Hallex
        <CommandMethod("FilletLines", "FLT", CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
        Public Shared Sub FilletLines()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    ' Prompt for the fillet radius
                    Dim pdo As New PromptDoubleOptions(vbLf & "Enter the fillet radius: ")
                    pdo.AllowZero = False
                    pdo.AllowNegative = False
                    pdo.AllowNone = False
                    Dim pdr As PromptDoubleResult = ed.GetDouble(pdo)
                    If pdr.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim rad As Double = pdr.Value
                    ' Prompt for the lines to be filleted
                    Dim peo As New PromptEntityOptions(vbLf & "Select first line:")
                    Dim per As PromptEntityResult = ed.GetEntity(peo)
                    If per.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim fid As ObjectId = per.ObjectId
                    peo.Message = vbLf & "Select second line:"
                        Return
                    End If
                    Dim sid As ObjectId = per.ObjectId
                    ' get entities
                    Dim ent1 As Entity = TryCast(tr.GetObject(fid, OpenMode.ForRead), Entity)
                    Dim ent2 As Entity = TryCast(tr.GetObject(sid, OpenMode.ForRead), Entity)
                    ' cast entites as lines
                    Dim line1 As Line = TryCast(ent1, Line)
                    Dim line2 As Line = TryCast(ent2, Line)
                    Dim intpts As New Point3dCollection()
                    ' get intersection between lines
                    If intpts.Count <> 1 Then
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Lines are colinear or does not intersects")
                        Return
                    End If
                    Dim ip As Point3d = intpts(0)
                    Dim midp1 As Point3d
                    Dim midp2 As Point3d
                    ' compare points
                    If Not (line1.StartPoint.Equals(ip)) Then
                        line1.UpgradeOpen()
                    End If
                    If Not (line2.StartPoint.Equals(ip)) Then
                        line2.UpgradeOpen()
                    End If
                    ' get point on bisector
                    Dim midp As New Point3d((midp1.X + midp2.X) / 2.0, (midp1.Y + midp2.Y) / 2.0, (midp1.Z + midp2.Z) / 2.0)
                    ' get angles along lines from intersection
                    Dim ang1 As Double = AngleFromX(ip, midp1)
                    Dim ang2 As Double = AngleFromX(ip, midp2)
                    ' get bisector angle
                    Dim ang As Double = AngleFromX(ip, midp)
                    ' calculate angle between lines
                    Dim angc As Double = Math.Abs(ang2 - ang1)
                    ' get a half of them
                    Dim bis As Double = angc / 2.0
                    ' calculate hypotenuse
                    Dim hyp As Double = rad / Math.Sin(bis)
                    ' calculate center point of filleting arc
                    Dim cp As Point3d = PolarPoint(ip, ang, hyp)
                    ' calculate another leg of a triangle
                    Dim cat As Double = Math.Sqrt((Math.Pow(hyp, 2)) - (Math.Pow(rad, 2)))
                    ' calculate center point on arc
                    Dim pa As Point3d = PolarPoint(ip, ang, hyp - rad)
                    ' calculate start point of arc
                    Dim ps As Point3d = PolarPoint(ip, ang1, cat)
                    ' calculate end point of arc
                    Dim pe As Point3d = PolarPoint(ip, ang2, cat)
                    ' define arc
                    Dim arc As New Arc()
                    ' check on direction of points
                    If isLeft(midp2, ip, midp1) Then
                        arc = New Arc(cp, rad, AngleFromX(cp, pe), AngleFromX(cp, ps))
                    Else
                        arc = New Arc(cp, rad, AngleFromX(cp, ps), AngleFromX(cp, pe))
                    End If
                    ' trim lines by arc
                    line1.UpgradeOpen()
                    line2.UpgradeOpen()
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    ' add arc to space
                    tr.AddNewlyCreatedDBObject(arc, True)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message)
                End Try
            End Using 'dispose transaction
        End Sub
Message 8 of 14
cean_au
in reply to: Hallex
thx Hallex.
            '/// Polar point // credit to Tony Tanzillo
            Public Shared Function PolarPoint(ByVal basepoint As Point3d, ByVal angle As Double, ByVal distance As Double) As Point3d
                Return New Point3d(basepoint.X + (distance * Math.Cos(angle)), basepoint.Y + (distance * Math.Sin(angle)), basepoint.Z)
            End Function
            Public Shared Function AngleFromX(ByVal pt1 As Point3d, ByVal pt2 As Point3d) As Double
                Dim ang As Double
                Dim vec As Vector3d
                Dim ucsplane As Plane
                ucsplane = New Plane(New Point3d(0, 0, 0), New Vector3d(0, 0, 1))
                vec = pt2 - pt1
                Return ang
            End Function
            '/// isleft function (edited) // credit to Bryco
            Public Shared Function isLeft(ByVal spt As Point3d, ByVal ept As Point3d, ByVal apt As Point3d) As Boolean
                Dim Ans As Double
                Dim result As Boolean
                result = False
                Ans = ((ept.X - spt.X) * (apt.Y - spt.Y) - (apt.X - spt.X) * (ept.Y - spt.Y))
                If (Ans > 0) Then
                    result = True
                Else
                    result = False
                End If
                Return result
            End Function
Message 9 of 14
Hallex
You're welcome
Cheers 🙂
~'J'~
Message 10 of 14
in reply to: Hallex
What about when we have line in 3D? Have you any idea? above code not work when one of the line is vertical.
Message 11 of 14
_gile
Here's a 3d working example.
using System;
using static System.Math;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(Fillet3D.Commands))]
namespace Fillet3D
    public class Commands
        double radius = 0.0;
        [CommandMethod("TEST")]
        public void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var pdo = new PromptDistanceOptions("\nEnter the fillet radius: ");
            pdo.DefaultValue = radius;
            pdo.AllowNone = true;
            pdo.UseDefaultValue = true;
            var pdr = ed.GetDistance(pdo);
            if (pdr.Status != PromptStatus.OK) return;
            radius = pdr.Value;
            var peo = new PromptEntityOptions("\nSelect the first line: ");
            peo.SetRejectMessage("\nSelected object is not a line.");
            peo.AddAllowedClass(typeof(Line), true);
            var per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            var id1 = per.ObjectId;
            var pp1 = ed.Snap("_near", per.PickedPoint).TransformBy(ed.CurrentUserCoordinateSystem);
            peo.Message = "\nSelect the second line: ";
            var id2 = per.ObjectId;
            var pp2 = ed.Snap("_near", per.PickedPoint).TransformBy(ed.CurrentUserCoordinateSystem);
            using (var tr = db.TransactionManager.StartTransaction())
                // open the lines
                var line1 = (Line)tr.GetObject(id1, OpenMode.ForRead);
                var line2 = (Line)tr.GetObject(id2, OpenMode.ForRead);
                // get the intersection
                var pts = new Point3dCollection();
                line1.IntersectWith(line2, Intersect.ExtendBoth, pts, IntPtr.Zero, IntPtr.Zero);
                if (pts.Count != 1)
                    ed.WriteMessage("\nSelected lines do not intersect.");
                    return;
                var inters = pts[0];
                var sp1 = line1.StartPoint;
                var ep1 = line1.EndPoint;
                var sp2 = line2.StartPoint;
                var ep2 = line2.EndPoint;
                // get the farest points from intersection on the picked side of both lines
                Func<Point3d, Point3d, Point3d, Point3d> getFarest = (sp, ep, pp) =>
                    var dir = inters.GetVectorTo(pp);
                    if (!inters.GetVectorTo(sp).IsCodirectionalTo(dir)) return ep;
                    if (!inters.GetVectorTo(ep).IsCodirectionalTo(dir)) return sp;
                    if (inters.DistanceTo(sp) < inters.DistanceTo(ep)) return ep;
                    return sp;
                var fp1 = getFarest(sp1, ep1, pp1);
                var fp2 = getFarest(sp2, ep2, pp2);
                // if radius == 0, just trim/extend the lines
                if (radius == 0.0)
                    if (sp1.IsEqualTo(line1.StartPoint))
                        line1.EndPoint = inters;
                    else
                        line1.StartPoint = inters;
                    if (sp2.IsEqualTo(line2.StartPoint))
                        line2.EndPoint = inters;
                    else
                        line2.StartPoint = inters;
                // compute the fillet
                else
                    // 2D work in the plane defined by the two lines
                    var normal = (fp1 - inters).CrossProduct(fp2 - inters);
                    var plane = new Plane(inters, normal);
                    var v1 = fp1.Convert2d(plane).GetAsVector();
                    var v2 = fp2.Convert2d(plane).GetAsVector();
                    double angle = v1.GetAngleTo(v2) / 2.0;
                    var dist = radius / Tan(angle);
                    if (v1.Length <= dist || v2.Length <= dist)
                        ed.WriteMessage("\nRadius too large to fillet the selected lines.");
                        return;
                    double hyp = radius / Sin(angle);
                    var center = new Point2d(hyp * Cos(angle + v1.Angle), hyp * Sin(angle + v1.Angle));
                    var p1 = Point2d.Origin + v1.GetNormal() * dist;
                    var p2 = Point2d.Origin + v2.GetNormal() * dist;
                    var a1 = center.GetVectorTo(p1).Angle;
                    var a2 = center.GetVectorTo(p2).Angle;
                    // back to 3D
                    Func<Point2d, Point3d> convert3d = (pt) =>
                        new Point3d(pt.X, pt.Y, 0.0).TransformBy(Matrix3d.PlaneToWorld(plane));
                    var arc = new Arc(new Point3d(center.X, center.Y, 0.0), radius, a2, a1);
                    arc.TransformBy(Matrix3d.PlaneToWorld(plane));
                    var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    curSpace.AppendEntity(arc);
                    line1.StartPoint = convert3d(p1);
                    line1.EndPoint = fp1;
                    line2.StartPoint = fp2;
                    line2.EndPoint = convert3d(p2);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 12 of 14
kdub_nz
in reply to: _gile
Hi Gilles, @_gile
Nice example of using Delegates !
Regards and thanks for all your hard work.
Kerry
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 13 of 14
_gile
in reply to: kdub_nz
KerryBrown a écrit :
Hi Gilles, @_gile
Kerry
Thanks Kerry, @kdub_nz
Delegates are an alternative to local functions which are coming with the C# 7 as tuples and pattern matching.
C# get closer to F# at each new version...
F# code
namespace Fillet3d
open System
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.EditorInput
open Autodesk.AutoCAD.Geometry
open Autodesk.AutoCAD.Runtime
type AcAp = Autodesk.AutoCAD.ApplicationServices.Application
type Command () =
    let mutable radius = 0.0
    [<CommandMethod("Test")>]
    member x.test () =
        let doc = AcAp.DocumentManager.MdiActiveDocument
        let db = doc.Database
        let ed = doc.Editor
        let pdo = PromptDistanceOptions("\nSpecify the radius: ")
        pdo.DefaultValue <- radius
        pdo.UseDefaultValue <- true
        pdo.AllowNegative <- false
        let pdr = ed.GetDistance(pdo)
        if (pdr.Status = PromptStatus.OK) then
            radius <- pdr.Value
            ed.WriteMessage("\nRadius = {0}", radius)
            let peo = PromptEntityOptions("\nSelect the first line: ")
            peo.AddAllowedClass(typeof<Line>, true)
            let per = ed.GetEntity(peo)
            if (per.Status = PromptStatus.OK) then
                let id1 = per.ObjectId
                let pp1 = ed.Snap("_near", per.PickedPoint).TransformBy(ed.CurrentUserCoordinateSystem)
                peo.Message <- "\nSelect the second line: "
                    let id2 = per.ObjectId
                    let pp2 = ed.Snap("_near", per.PickedPoint).TransformBy(ed.CurrentUserCoordinateSystem)
                    use tr = db.TransactionManager.StartTransaction()
                    // open the lines
                    let line1 = tr.GetObject(id1, OpenMode.ForRead) :?> Line
                    let line2 = tr.GetObject(id2, OpenMode.ForRead) :?> Line
                    let pts = new Point3dCollection()
                    if (pts.Count = 0) then
                    else
                        let inters = pts.[0]
                        let getFarest sp ep pp =
                            let dir = pp - inters
                            if not ((sp - inters).IsCodirectionalTo(dir)) then ep
                            elif not ((ep - inters).IsCodirectionalTo(dir)) then sp
                            elif inters.DistanceTo(sp) < inters.DistanceTo(ep) then ep
                            else sp
                        let fp1 = getFarest line1.StartPoint line1.EndPoint pp1
                        let fp2 = getFarest line2.StartPoint line2.EndPoint pp2
                        // if radius equals 0.0, just trim or extend the lines
                        if radius = 0.0 then
                            let trimExtend (line: Line) fp =
                                line.UpgradeOpen()
                                if line.StartPoint.IsEqualTo(fp)
                                then line.EndPoint <- inters
                                else line.StartPoint <- inters
                            trimExtend line1 fp1
                            trimExtend line2 fp2
                        else // compute the fillet
                            // 2D work in the plane defined by the 2 lines
                            let norm = (fp1 - inters).CrossProduct(fp2 - inters)
                            let plane = new Plane(inters, norm)
                            let v1 = fp1.Convert2d(plane).GetAsVector()
                            let v2 = fp2.Convert2d(plane).GetAsVector()
                            let ang = v1.GetAngleTo(v2) / 2.
                            let dist = radius / tan ang
                            if (v1.Length <= radius || v2.Length <= radius) then
                                ed.WriteMessage("\nRadius too large too fillet the lines.")
                            else
                                let hyp = radius / sin ang
                                let cen = Point2d(hyp * cos (ang + v1.Angle), hyp * sin (ang + v1.Angle))
                                let pointAngle (v : Vector2d) =
                                    let p = Point2d.Origin + v.GetNormal() * dist
                                    (p, (p - cen).Angle)
                                let (p1, a1) = pointAngle v1
                                let (p2, a2) = pointAngle v2
                                // back to 3D
                                let arc = new Arc(Point3d(cen.X, cen.Y, 0.0), radius, a2, a1)
                                let space = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) :?> BlockTableRecord
                                space.AppendEntity(arc) |> ignore
                                let convert3d (pt : Point2d) =
                                let trimExtend (line : Line) fp p =
                                    line.UpgradeOpen()
                                    then line.EndPoint <- convert3d p
                                    else line.StartPoint <- convert3d p
                                trimExtend line1 fp1 p1
                                trimExtend line2 fp2 p2
                    tr.Commit()
Gilles Chanteau
GileCAD
GitHub
Message 14 of 14
Kélcyo
in reply to: _gile
what would be the implementation to join the lines with the arc forming a spline
”Boost
