.NET
.NET
0 Kudos
Post 1 of 9
how to Draw/create fillet using .NET ?
1722 Views, 8 Replies
01-12-2010 09:51 PM
I created a rectangle using draw line (i am wirking on Autocad 2010)
Now I want to create 4 fillets at each corner with some radius using vb.net
Please somebody help me please
dipak Edited by: dip_nik on Jan 13, 2010 11:22 AM
171 Kudos
Post 2 of 9
Re: how to Draw/create fillet using .NET ?
01-15-2010 01:06 AM in reply to: dip_nik
This one is a bit tricky but working for mein A2008
(spell all prompts)
{code}
using System;
using System.Text;
using System.Collections;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CurveMod
public class CurveModify
[CommandMethod("FLT", CommandFlags.UsePickSet & CommandFlags.Redraw)]
static public void FilletLines()
Database db = HostApplicationServices.WorkingDatabase;
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
try
// Prompt for the fillet radius
PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter the fillet radius: ");
pdo.AllowZero = false;
pdo.AllowNegative = false;
pdo.AllowNone = false;
PromptDoubleResult pdr = ed.GetDouble(pdo);
if (pdr.Status != PromptStatus.OK)
return;
double rad = pdr.Value;
// Prompt for the lines to fillet
PromptEntityOptions peo = new PromptEntityOptions("\nSelect first line:");
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
ObjectId fid = per.ObjectId;
peo.Message = "\nSelect second line:";
return;
ObjectId sid = per.ObjectId;
// get entities
Entity ent1 = tr.GetObject(fid, OpenMode.ForRead) as Entity;
Entity ent2 = tr.GetObject(sid, OpenMode.ForRead) as Entity;
// cast entites as lines
Line line1 = ent1 as Line;
Line line2 = ent2 as Line;
Point3dCollection intpts = new Point3dCollection();
// get intersection between lines
line1.IntersectWith(line2, Intersect.OnBothOperands, intpts, 0, 0);
if (intpts.Count != 1)
acadApp.ShowAlertDialog("Lines are colinear or does not intersects");
return;
Point3d ip = intpts[0];
Point3d midp1;
Point3d midp2;
// compare points
if (!(line1.StartPoint.Equals(ip)))
line1.UpgradeOpen();
line1.EndPoint = line1.StartPoint;
line1.StartPoint = ip;
midp1 = line1.GetPointAtDist(rad);
if (!(line2.StartPoint.Equals(ip)))
line2.UpgradeOpen();
line2.EndPoint = line2.StartPoint;
line2.StartPoint = ip;
midp2 = line2.GetPointAtDist(rad);
// get point on bisector
Point3d midp = new Point3d(
(midp1.X + midp2.X) / 2.0,
(midp1.Y + midp2.Y) / 2.0,
(midp1.Z + midp2.Z) / 2.0);
// get angles along lines from intersection
double ang1 = AngleFromX(ip, midp1);
double ang2 = AngleFromX(ip, midp2);
// get bisector angle
double ang = AngleFromX(ip, midp);
// calculate angle between lines
double angc = Math.Abs(ang2 - ang1);
// get a half of them
double bis = angc / 2.0;
// calculate hypotenuse
double hyp = rad / Math.Sin(bis);
// calculate center point of filleting arc
Point3d cp = PolarPoint(ip, ang, hyp);
// calculate another leg of a triangle
double cat = Math.Sqrt((Math.Pow(hyp, 2)) - (Math.Pow(rad, 2)));
// calculate center point on arc
Point3d pa = PolarPoint(ip, ang, hyp - rad);
// calculate start point of arc
Point3d ps = PolarPoint(ip, ang1, cat);
// calculate end point of arc
Point3d pe = PolarPoint(ip, ang2, cat);
// define arc
Arc arc = new Arc();
// check on direction of points
if (isLeft(midp2, ip, midp1))
arc = new Arc(cp, rad, AngleFromX(cp, pe), AngleFromX(cp, ps));
else
arc = new Arc(cp, rad, AngleFromX(cp, ps), AngleFromX(cp, pe));
// trim lines by arc
line1.StartPoint = ps;
line2.StartPoint = pe;
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
// add arc to space
btr.AppendEntity(arc);
tr.AddNewlyCreatedDBObject(arc, true);
tr.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
acadApp.ShowAlertDialog(ex.Message);
}//dispose transaction
/// Polar point // credit to Tony Tanzillo
public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
return new Point3d(
basepoint.X + (distance * Math.Cos(angle)),
basepoint.Y + (distance * Math.Sin(angle)),
basepoint.Z);
public static double AngleFromX(Point3d pt1, Point3d pt2)
Plane ucsplane = new Plane(new Point3d(0, 0, 0), new Vector3d(0, 0, 1));
Vector3d vec = pt2 - pt1;
double ang = vec.AngleOnPlane(ucsplane);
return ang;
/// isleft function (edited) // credit to Bryco
public static bool isLeft(Point3d spt, Point3d ept, Point3d apt)
bool result = false;
double Ans = ((ept.X - spt.X) * (apt.Y - spt.Y) -
(apt.X - spt.X) * (ept.Y - spt.Y));
if (Ans > 0)
result = true;
else
result = false;
return result;
{code}
~'J'~
0 Kudos
Post 3 of 9
01-17-2010 08:40 PM in reply to: dip_nik
Hi hallex ,
Thanks a lottttttttt
for the reply.
Have a nice Day
171 Kudos
Post 4 of 9
01-17-2010 10:33 PM in reply to: dip_nik
Glad to help
Cheers :smileyhappy:
~'J'~
Valued Contributor
2 Kudos
Post 5 of 9
12-26-2011 07:56 PM in reply to: dip_nik
is there a vb.net version?
thx
ADN Support Specialist
100 Kudos
Post 6 of 9
12-26-2011 08:19 PM in reply to: cean_au
Here is a link that I personally find useful in converting code from C# to VB.Net and vice-versa.
Some basic things will need to be fixed if you get some compile errors.
http://www.developerfusion.com/tools/convert/csharp-to-vb/
Balaji
Developer Technical Services
Autodesk Developer Network
171 Kudos
Post 7 of 9
12-27-2011 12:52 AM in reply to: cean_au
        <CommandMethod("FilletLines", "FLT", CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
        Public Shared Sub FilletLines()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    ' Prompt for the fillet radius
                    Dim pdo As New PromptDoubleOptions(vbLf & "Enter the fillet radius: ")
                    pdo.AllowZero = False
                    pdo.AllowNegative = False
                    pdo.AllowNone = False
                    Dim pdr As PromptDoubleResult = ed.GetDouble(pdo)
                    If pdr.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim rad As Double = pdr.Value
                    ' Prompt for the lines to be filleted
                    Dim peo As New PromptEntityOptions(vbLf & "Select first line:")
                    Dim per As PromptEntityResult = ed.GetEntity(peo)
                    If per.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim fid As ObjectId = per.ObjectId
                    peo.Message = vbLf & "Select second line:"
                        Return
                    End If
                    Dim sid As ObjectId = per.ObjectId
                    ' get entities
                    Dim ent1 As Entity = TryCast(tr.GetObject(fid, OpenMode.ForRead), Entity)
                    Dim ent2 As Entity = TryCast(tr.GetObject(sid, OpenMode.ForRead), Entity)
                    ' cast entites as lines
                    Dim line1 As Line = TryCast(ent1, Line)
                    Dim line2 As Line = TryCast(ent2, Line)
                    Dim intpts As New Point3dCollection()
                    ' get intersection between lines
                    If intpts.Count <> 1 Then
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Lines are colinear or does not intersects")
                        Return
                    End If
                    Dim ip As Point3d = intpts(0)
                    Dim midp1 As Point3d
                    Dim midp2 As Point3d
                    ' compare points
                    If Not (line1.StartPoint.Equals(ip)) Then
                        line1.UpgradeOpen()
                    End If
                    If Not (line2.StartPoint.Equals(ip)) Then
                        line2.UpgradeOpen()
                    End If
                    ' get point on bisector
                    Dim midp As New Point3d((midp1.X + midp2.X) / 2.0, (midp1.Y + midp2.Y) / 2.0, (midp1.Z + midp2.Z) / 2.0)
                    ' get angles along lines from intersection
                    Dim ang1 As Double = AngleFromX(ip, midp1)
                    Dim ang2 As Double = AngleFromX(ip, midp2)
                    ' get bisector angle
                    Dim ang As Double = AngleFromX(ip, midp)
                    ' calculate angle between lines
                    Dim angc As Double = Math.Abs(ang2 - ang1)
                    ' get a half of them
                    Dim bis As Double = angc / 2.0
                    ' calculate hypotenuse
                    Dim hyp As Double = rad / Math.Sin(bis)
                    ' calculate center point of filleting arc
                    Dim cp As Point3d = PolarPoint(ip, ang, hyp)
                    ' calculate another leg of a triangle
                    Dim cat As Double = Math.Sqrt((Math.Pow(hyp, 2)) - (Math.Pow(rad, 2)))
                    ' calculate center point on arc
                    Dim pa As Point3d = PolarPoint(ip, ang, hyp - rad)
                    ' calculate start point of arc
                    Dim ps As Point3d = PolarPoint(ip, ang1, cat)
                    ' calculate end point of arc
                    Dim pe As Point3d = PolarPoint(ip, ang2, cat)
                    ' define arc
                    Dim arc As New Arc()
                    ' check on direction of points
                    If isLeft(midp2, ip, midp1) Then
                        arc = New Arc(cp, rad, AngleFromX(cp, pe), AngleFromX(cp, ps))
                    Else
                        arc = New Arc(cp, rad, AngleFromX(cp, ps), AngleFromX(cp, pe))
                    End If
                    ' trim lines by arc
                    line1.UpgradeOpen()
                    line2.UpgradeOpen()
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    ' add arc to space
                    tr.AddNewlyCreatedDBObject(arc, True)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message)
                End Try
            End Using 'dispose transaction
        End Sub
Valued Contributor
2 Kudos
Post 8 of 9
12-29-2011 12:46 AM in reply to: Hallex
thx Hallex.
            '/// Polar point // credit to Tony Tanzillo
            Public Shared Function PolarPoint(ByVal basepoint As Point3d, ByVal angle As Double, ByVal distance As Double) As Point3d
                Return New Point3d(basepoint.X + (distance * Math.Cos(angle)), basepoint.Y + (distance * Math.Sin(angle)), basepoint.Z)
            End Function
            Public Shared Function AngleFromX(ByVal pt1 As Point3d, ByVal pt2 As Point3d) As Double
                Dim ang As Double
                Dim vec As Vector3d
                Dim ucsplane As Plane
                ucsplane = New Plane(New Point3d(0, 0, 0), New Vector3d(0, 0, 1))
                vec = pt2 - pt1
                Return ang
            End Function
            '/// isleft function (edited) // credit to Bryco
            Public Shared Function isLeft(ByVal spt As Point3d, ByVal ept As Point3d, ByVal apt As Point3d) As Boolean
                Dim Ans As Double
                Dim result As Boolean
                result = False
                Ans = ((ept.X - spt.X) * (apt.Y - spt.Y) - (apt.X - spt.X) * (ept.Y - spt.Y))
                If (Ans > 0) Then
                    result = True
                Else
                    result = False
                End If
                Return result
            End Function
171 Kudos
Post 9 of 9
12-29-2011 04:31 AM in reply to: cean_au
You're welcome
~'J'~
