.NET
Valued Contributor
swaywood
Message 1 of 8 (307 Views)
How to draw a revcloud?
307 Views, 7 Replies
03-18-2014 01:37 AM
now i have the polyline object id, but i don't know how to create a revcloud by select a object by code, and generate a revcloud entity.
        public static void drawRevCloudLine(ObjectId polyId, double scale)
            //最小弧长
            string smallArc = Math.Ceiling(2.0 / scale).ToString();
            //最大弧长
            string largeArc = Math.Ceiling(6.0 / scale).ToString();
            //运行命令
            ResultBuffer rb = new ResultBuffer();
            rb.Add(new TypedValue(5005, "_revcloud"));
            rb.Add(new TypedValue(5005, "_a"));
            rb.Add(new TypedValue(5005, smallArc));
            rb.Add(new TypedValue(5005, largeArc));
            rb.Add(new TypedValue(5006, polyId));
            rb.Add(new TypedValue(5005, "_n"));
            try
                acedCmd(rb.UnmanagedObject);
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Editor editor = doc.Editor;
                Polyline rev=new Polyline();
                editor.Command("_revcloud", "_a", smallArc, largeArc, polyId, "_n");
            catch (System.Exception ex)
                AcadApp.ShowAlertDialog(ex.StackTrace + "\n" + ex.Message);
            finally
                rb.Dispose();
 the following is the support code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Linq.Expressions;
using System.Reflection;
using Autodesk.AutoCAD.ApplicationServices;
namespace Autodesk.AutoCAD.EditorInput
    public static class EditorInputExtensionMethods
        public static PromptStatus Command(this Editor editor, params object[] args)
            if (editor == null)
                throw new ArgumentNullException("editor");
            return runCommand(editor, args);
        static Func<Editor, object[], PromptStatus> runCommand = GenerateRunCommand();
        static Func<Editor, object[], PromptStatus> GenerateRunCommand()
            MethodInfo method = typeof(Editor).GetMethod("RunCommand",
               BindingFlags.Instance | BindingFlags.NonPublic | BindingFlags.Public);
            var instance = Expression.Parameter(typeof(Editor), "instance");
            var args = Expression.Parameter(typeof(object[]), "args");
            return Expression.Lambda<Func<Editor, object[], PromptStatus>>(
               Expression.Call(instance, method, args), instance, args)
                  .Compile();
Have a try with the posted solution.
It defines two commands: CLOUD1 using RunCommand and CLOUD2 using acedCmd.
Both work as expected on my AutoCAD 2013.
_gile
Message 2 of 8 (294 Views)
Re : How to draw a revcloud?
03-18-2014 03:32 AM in reply to: swaywood
It seems you're confusing.
Use acedCmd or runCommand but not both
P/Invoking acedCmd
        private void drawRevCloudLine(ObjectId polyId, double scale)
            ResultBuffer args = new ResultBuffer(
                new TypedValue((int)LispDataType.Text, "_revcloud"),
                new TypedValue((int)LispDataType.Text, "_arc"),
                new TypedValue((int)LispDataType.Double, 2.0 / scale),
                new TypedValue((int)LispDataType.Text, "_object"),
                new TypedValue((int)LispDataType.ObjectId, polyId),
                new TypedValue((int)LispDataType.Text, "_no"));
            Command(args);
Using runCommand wrapper
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.Command("_revcloud", "_arc", 2.0 / scale, 6.0 / scale, "_object", polyId, "_no");
Gilles Chanteau
Valued Contributor
swaywood
Message 3 of 8 (271 Views)
Re: How to draw a revcloud?
03-18-2014 07:51 AM in reply to: swaywood
Hi,Gilles:
    I tried several times, but not joy. So i made an entire sample, please check for me, and point out where the code is wrong.
    autocad2013+framwork4.0+vs2010
regards
swaywood
_gile
Message 4 of 8 (259 Views)
03-18-2014 01:15 PM in reply to: swaywood
Your code does not work beacause you try to add to the current space and the transaction the polyligne created by the revcloud command.
You don't have to matter for this while you're calling AutoCAD commands, AutoCAD will do all this stuff for you.
Here's a way using the runCommand route and some other extension methods.
using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Acad2013CsTemplate
    public class Commands
        [CommandMethod("CLOUD")]
        public void Cloud()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptPointResult ppr = ed.GetPoint("\nSpecify the first corner: ");
            if (ppr.Status != PromptStatus.OK) return;
            Point3d pt1 = ppr.Value;
            ppr = ed.GetCorner("\nSpecify the opposite corner: ", pt1);
            Point3d pt2 = ppr.Value;
            ObjectId id;
            using (Transaction tr = db.TransactionManager.StartTransaction())
            using (Polyline pline = new Polyline(4))
                pline.AddVertexAt(0, new Point2d(pt1.X, pt1.Y), 0.0, 0.0, 0.0);
                pline.AddVertexAt(1, new Point2d(pt2.X, pt1.Y), 0.0, 0.0, 0.0);
                pline.AddVertexAt(2, new Point2d(pt2.X, pt2.Y), 0.0, 0.0, 0.0);
                pline.AddVertexAt(3, new Point2d(pt1.X, pt2.Y), 0.0, 0.0, 0.0);
                pline.Closed = true;
                id = db.GetCurrentSpace(OpenMode.ForWrite).Add(pline);
                tr.Commit();
            ed.Command("_revcloud", "_arc", 2.0, 6.0, "_object", id, "_no");
    public static class Extension
        public static PromptStatus Command(this Editor ed, params object[] args)
            if (ed == null)
                throw new ArgumentNullException("ed");
            return runCommand(ed, args);
                "RunCommand", BindingFlags.Instance | BindingFlags.NonPublic | BindingFlags.Public);
            ParameterExpression instance = Expression.Parameter(typeof(Editor), "ed");
            ParameterExpression args = Expression.Parameter(typeof(object[]), "args");
                  .Compile();
        public static T GetObject<T>(this ObjectId id, OpenMode mode)
            where T : DBObject
            return (T)id.GetObject(mode);
        public static BlockTableRecord GetCurrentSpace(this Database db, OpenMode mode)
            return db.CurrentSpaceId.GetObject<BlockTableRecord>(mode);
        public static ObjectId Add(this BlockTableRecord owner, Entity ent)
            ObjectId id = owner.AppendEntity(ent);
            owner.Database.TransactionManager.AddNewlyCreatedDBObject(ent, true);
            return id;
Gilles Chanteau
Valued Contributor
swaywood
Message 5 of 8 (248 Views)
03-18-2014 06:37 PM in reply to: swaywood
Hi Gilles:
Unfortunatelly, I failed again.
Is there any systemvalue shall be set in AutoCAD?
I only got the Rectangle again.
And when I test by step, I found when run to line
'id = db.GetCurrentSpace(OpenMode.ForWrite).Add(pline);'
the code swith to func GenerateRunCommand.
And when the code run to line 'ed.Command("_revcloud", "_arc", 2.0, 6.0, "_object", id, "_no");'
It can run to 'return RunCommand(ed, args);'
but can not run into 'func GenerateRunCommand'
at last quit step by step.
Were you got the 'RevCloud' successfully?
PS:I found some 'runCommand', I changed it to 'RunCommand', but it seems no influence.
thanks
swaywood
_gile
Message 6 of 8 (238 Views)
03-19-2014 01:28 AM in reply to: swaywood
Gilles Chanteau
Valued Contributor
swaywood
Message 7 of 8 (232 Views)
03-19-2014 02:46 AM in reply to: _gile
Hi Gilles:
    I found the problem where was, in autocad2013 there is a systemvalue 'nextfiberworld', I changed it to '0' before, so all the methods can not works fine, After change the value to 1, I got it both.
    now i can draw the revsion cloud, but i do not know why the 'nextfiberworld' can control the both mthods?
thanks so much!
swaywood
Hallex
Message 8 of 8 (196 Views)
03-21-2014 01:23 PM in reply to: swaywood
Here is another one using command way:
        //ads_queueexpr
        [DllImport("accore.dll", CharSet = CharSet.Unicode,
CallingConvention = CallingConvention.Cdecl,
EntryPoint = "ads_queueexpr")]
        extern static private int ads_queueexpr(byte[] command);
         public void CurveCloud(string hdl){
         UnicodeEncoding uEncode = new UnicodeEncoding();
         string hand=  string.Format("(handent  \"{0}\")",hdl);
         ads_queueexpr(uEncode.GetBytes("(command \"_.revcloud\" \"_arc\" \"2.54\" \"7.62\" \"_Ob\" " +  hand  + " \"N\"" + ")"));
        [CommandMethod("revc")]
        public void MakeRevCloud()
             var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            using (var tr = doc.TransactionManager.StartTransaction())
                ObjectId id = ed.GetEntity("\nSelect Closed curve").ObjectId;
                if (id != ObjectId.Null)
                    DBObject obj = tr.GetObject(id, OpenMode.ForRead);
                    string hdl = obj.Handle.ToString();
                    obj.UpgradeOpen();
                    CurveCloud(hdl);
                    tr.Commit();
