.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 5
How to do this effect? after ReDo command
213 Views, 4 Replies
02-13-2012 03:04 AM
Hi Guys,
I use AutoCAD 2011, VB.net
I have done a form docked on the left side of drawing dynamicly display all block in the drawing. What I have done is select all block druing drawing open process and put them into listview in the form and display them.
Once I delete some of the block, they will be removed from my form as well.
Now is my question. If I send redo command(Ctrl+Z), those deleted block will be put back to drawing, I wonder how to update my form at the same time? I could get all blocks again and refresh the listview. But I think that will take sometime if I have  lots blocks in the drawing.
Any ideas?
Yaqi
1,210 Kudos
Post 2 of 5
Re: How to do this effect? after ReDo command
02-13-2012 03:51 AM in reply to: yaqiz
Check for event "CommandEnded" or for "ObjectAdded" (I think it will be raised when you do a _REDO)
- alfred -
Alfred NESWADBA
Valued Contributor
1 Kudo
Post 3 of 5
02-13-2012 03:56 AM in reply to: Alfred.NESWADBA
Thanks for the hint. Do you know where is ObjectAdded?
T
1,210 Kudos
Post 4 of 5
02-13-2012 04:24 AM in reply to: yaqiz
It's an event in the Autodesk.AutoCAD.DatabaseServices.Database - object.
- alfred -
Alfred NESWADBA
Valued Contributor
1 Kudo
Post 5 of 5
02-28-2012 06:54 AM in reply to: Alfred.NESWADBA
Hi Alfred,
I just did a test. It didn't trigger objectadded when I use redo.
