.NET
how to do method "distinct<>" for objects Autodesk.AutoCAD.Geometry.Point2d ?
11 REPLIES 11
Message 1 of 12
joantopo
1242 Views, 11 Replies
I have this:
  #region IEquatable<Points> Members
            public bool Equals(Points other)
            if (Object.ReferenceEquals(other, null)) return false;
            if (Object.ReferenceEquals(this, other)) return true;
            return this.PointNumber.Equals(other.PointNumber);
          public override int GetHashCode()
             int hashDescription = this.PointNumber == null ? 0 : this.PointNumber.GetHashCode();
                return hashDescription;
      #endregion
 to distinct repeat cogo points(civil 3d) about its PointNumber.
Now, I want the same but Point2d Collection, however it doesn´t work:
namespace toolsC3D
    public class Vertex : IEquatable<Vertex>
        #region IEquatable<Vertex> Members
        public bool Equals(Vertex other)
            return this.punto2d.Equals(other.punto2d);
            int hashDescription = this.punto2d == null ? 0 : this.punto2d.GetHashCode();
        #endregion
        private Autodesk.AutoCAD.Geometry.Point2d mipunto2d = new Autodesk.AutoCAD.Geometry.Point2d(0,0);
        public Autodesk.AutoCAD.Geometry.Point2d punto2d
            get { return mipunto2d; }
            set { mipunto2d = value; }
 How can I delete all repeated location of point2D in a point2d Collection?
Can I do distinct with both conditions?  point2d.X and point2d.Y?
I have seen that Point2dCollection has IsEqual() method but I don´t know how I could use it.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
11 REPLIES 11
Message 2 of 12
zrobert
in reply to: joantopo
Hi;
Try something like this. (I'm not tested this code):
public Point2dCollection RemoveDuplicates(Point2dCollection coll)
    var distinctItems = coll.ToArray().Distinct(new Point2DComparer());
    var c = distinctItems.ToArray();
    return new Point2dCollection(c);
class Point2DComparer : IEqualityComparer<Point2d>
    public bool Equals(Point2d pt1, Point2d pt2)
        return System.Math.Abs(pt1.X - pt2.X) < 0.0001
            && System.Math.Abs(pt1.Y - pt2.Y) < 0.0001;
    public int GetHashCode(Point2d pt)
        return pt.GetHashCode();
Message 3 of 12
_gile
you can also use the Point2d.IsEqualTo(Point2d a) or Point2d.IsEqualTo (Point2d a, Tolerance tolerance) method.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 12
joantopo
in reply to: _gile
Yes, but I have points in the same collection. Perhaps I have to clone or copy collection and compare them to each other with IsEqual().
Message 5 of 12
_gile
You can use one of these overloaded RemoveDuplicates() extension methods.
They return a Point2d lazy sequence (IEnumerable<Point2d>) which can be iterated with foreach or converted into a Point2d array or list.
They can be called as a Point2dCollection instance method, a Point2d[] instance method or a List<Point2d> instance method.
A Tolerance can be passed as argument to be used for equality comparison, if none argument is passed the Tolerence.Global is used.
    public static class Point2dExtensions
        private static Tolerance tolerance;
        public static IEnumerable<Point2d> RemoveDuplicates(this Point2dCollection source)
            return source.Cast<Point2d>().RemoveDuplicates(Tolerance.Global);
        public static IEnumerable<Point2d> RemoveDuplicates(this Point2dCollection source, Tolerance tolerance)
            return source.Cast<Point2d>().RemoveDuplicates(tolerance);
        public static IEnumerable<Point2d> RemoveDuplicates(this IEnumerable<Point2d> source)
            return source.RemoveDuplicates(Tolerance.Global);
        public static IEnumerable<Point2d> RemoveDuplicates(this IEnumerable<Point2d> source, Tolerance tolerance)
            if (source == null)
                throw new ArgumentNullException("source");
Point2dExtensions.tolerance = tolerance; return source.Distinct(new Point2dComparer()); } class Point2dComparer : IEqualityComparer<Point2d> { public bool Equals(Point2d a, Point2d b) { return a.IsEqualTo(b, Point2dExtensions.tolerance); } public int GetHashCode(Point2d pt) { return 0; } } }
Gilles Chanteau
GileCAD
GitHub
Message 6 of 12
_gile
in reply to: _gile
If you want to use the HashCode in the equality comparison, you can replace the Point2dequalityComparer with this one (but I'm not sure it's more efficient).
                return new Point2d(Round(pt.X), Round(pt.Y)).GetHashCode();
            private double prec = Point2dExtensions.tolerance.EqualPoint * 10.0;
            private double Round(double num)
                if (prec == 0.0)
                    return num;
                else
                    return Math.Floor(num / prec + 0.5) * prec;
Gilles Chanteau
GileCAD
GitHub
Message 7 of 12
joantopo
in reply to: _gile
gile, I have already tried both code amb both doesn´t work.
I have 12 vertex and 2 repited vertex and returns equally 12.
Message 8 of 12
joantopo
I use this, but I think that it shoud be something more efficient;
 public static void RemoveDuplicates(this Point2dCollection source)
            for (int i = 0; i <= source.Count - 1; i++)
                for (int k = 0; k <= source.Count - 1; k++)
                    if (k > i)
                    if(source[i].IsEqualTo(source[k]))
                        source.RemoveAt(k);
                        k--;
Message 9 of 12
joantopo
in reply to: zrobert
Sorry, your method works fine. Could it be possible to do the same (distinct) for point3dcollection and objectIdCollection?
Message 10 of 12
zrobert
Hi;
For Point3DCollection, do this changes:
public Point3dCollection RemoveDuplicates(Point3dCollection collection)
            var a = collection.Cast<Point3d>();
            var distinctItems = a.Distinct(new Point3DComparer());
            return new Point3dCollection(c);
private class Point3DComparer : IEqualityComparer<Point3d>
            public bool Equals(Point3d pt1, Point3d pt2)
                       && System.Math.Abs(pt1.Z - pt2.Z) < 0.0001;
            public int GetHashCode(Point3d point)
                return point.GetHashCode();
Chears...
Message 11 of 12
zrobert
For ObjectIdCollection, try the same thing. ObjectIdCollection implements IList interface just
like Point3DCollection. Dont forget to change comparation logic in "SomeObject"Comparer class.
But, I think that you can avoid collection of duplicate ObjectId members...
Message 12 of 12
joantopo
Thanks zrobert. Yes, in some cases I can avoid do "distinct" for objectIdCollection but in other cases(for example when I get all breaklines from surface in Civil 3D, we could have repeated breaklines).
”Boost
