When prompt for input a point from user. I need also an option if they input a keyword like 'T'. We will open 1 form. After close this form. We back to prompt for a point again. Pls help.
Solved by Ed.Jobe. Go to Solution.
Check out the GetKeyWords method here.
Not only get a key word. I need something like the way using 'initget' in AutoLISP. A prompt that user can input a point or a kword.
That's why I linked to that method's parent topic. There are other options, GetString, GetObject, GetPoint. Did you read them? Prompting the user for info all works the same way and they all have examples and use similar techniques.
You're welcome.
