.NET
How to do like 'initget' (AutoLISP) in .net
5 REPLIES 5
689 Views, 5 Replies
When prompt for input a point from user. I need also an option if they input a keyword like 'T'.  We will open 1 form. After close this form. We back to prompt for a point again. Pls help.
5 REPLIES 5
Ed.Jobe
Check out the GetKeyWords method here.
Ed
How to post your code.
in reply to: Ed.Jobe
Not only get a key word. I need something like the way using 'initget' in AutoLISP. A prompt that user can input a point or a kword.
Ed.Jobe
That's why I linked to that method's parent topic. There are other options, GetString, GetObject, GetPoint. Did you read them? Prompting the user for info all works the same way and they all have examples and use similar techniques.
Ed
Thank you so much. I found it already. In'Control User Input' content.
Ed.Jobe
You're welcome.
Ed
”Boost
