.NET
New Member
coberto
Message 1 of 2 (126 Views)
How to do an "Add In" in .Net for Autocad
126 Views, 1 Replies
03-21-2006 11:05 AM
I made an Add In in .Net, and the program that start with the Add In is Autocad. But I can´t connect.
In the class Connect.vb i put a break point in Public Sub OnConnection, but the compiler never pass for that. I know that some keys in the Windows Registry are necessary. Please Help..!!!!!!
Active Contributor
karenina
Message 2 of 2 (126 Views)
Re: How to do an "Add In" in .Net for Autocad
04-19-2006 03:56 AM in reply to: coberto
You are right, you must load the assembly in AutoCAD.
To do this, you can write netload in autoCAD commandline and then select the dll that represents your addin.
Another option is to write something in the registry. Should be like this:
\\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\releaseNum\
ACAD-ProductID:LocaleID\
Applications\
YourApplicationName\
DESCRIPTION: REG_SZ: User Friendly App Name
LOADCTRLS: REG_DWORD: loadReason
LOADER: REG_SZ: pathFileName
Commands\
GlobalCommandName1:REG_SZ:LocalCommandName1
GlobalCommandName2:REG_SZ:LocalCommandName2
GlobalCommandName3:REG_SZ:LocalCommandName3
GlobalCommandName4:REG_SZ:LocalCommandName4
GlobalCommandName5:REG_SZ:LocalCommandName5
Groups\
GroupName:REG_SZ:GroupName
For AutoCAD 2006:
releaseNum = R16.2
ACAD-ProductID:LocaleID = ACAD-4003:409
loadReason:
0x01 - Load the application upon detection of proxy object.
0x02 - Load the application upon AutoCAD startup.
0x04 - Load the application upon invocation of a command.
0x08 - Load the application upon request by the user or another application.
0x10 - Do not load the application.
0x20 - Load the application transparently
Usually it is 0x02, but depends on what you need
pathFileName = must include the full path and file name of the module that AutoCAD should load first. The loader module is subsequently responsible for loading any other modules that make up the application.
For example, my addin writes this in the registry (I am giving you the code in C#):
string acadAddinKey = @"Software\Autodesk\AutoCAD\R16.2\ACAD-4003:409\Applications\MPMAcad2006PluginApplication";
RegistryKey addinKey = Registry.LocalMachine.CreateSubKey(acadAddinKey);
addinKey.SetValue("DESCRIPTION", "Matrix MPM AutoCAD Plugin");
addinKey.SetValue("LOADER", "D:\\Program Files\\Autodesk\\MDT 2006\\MM\\MM.Acad2006Plugin.Core.dll");
addinKey.SetValue("LOADCTRLS", 2);
addinKey.SetValue("MANAGED", 1);
I hope this helped you. I suggest you use the ObjectARXDocumentation.
Announcements
Need installation help?
