.NET
Member
yyjpz2007
Message 1 of 2 (127 Views)
how to develop a ActiveX in web
127 Views, 1 Replies
08-08-2012 05:18 AM
i wan't to view the dwg in web with ActiveX,but  i  need't  function of " save , print ,edit."
so  how  i  can develop the ActiveX?
can you tell me  some idea?
the .net plug can convet to  web ActiveX?
khoa.ho
Message 2 of 2 (103 Views)
Re: how to develop a ActiveX in web
08-08-2012 09:11 PM in reply to: yyjpz2007
You should have the source code to read binary DWG files (in different format versions). I don't see open source projects to read fully the DWG format. Most of them are commercial or closed-code. So we have to write our own code, or use the license library to read DWG files.
The codeproject.com has lots of links to help develop ActiveX in COM or .NET. I think you might start to use a library to read all entities in a DWG file first, and then draw them to the canvas (for example System.Drawing.Graphics class using GDI+). The output can be WinForm, WPF, Silverlight or ActiveX depending on your choice. This is lots of work and good luck to you.
-Khoa
