.NET
How to determine collection point on ARC or circle
5 REPLIES 5
596 Views, 5 Replies
Hi All,
I have 1 problem, hope everybody can help me. This is, I have 1 arc and now i want to get all point on this arc.
I have attached image.
5 REPLIES 5
HI,
Usually an arc consists of 3 points. Start, Center and End point. But from your picture it seems like that there is more than 3 points. can you clarify more regarding your problem?
Yes, i can get 3 point(start,point,middle) but if i want to get any more point in arc. How can i do that. thanks for your help.
hgasty1001
An arc is a curve class derived, so you can get points on the arc with something like this:
dim sp,ep as double
dim dp as double= 0.1 '<--Set this var to any value in order to obtain dense or sparse points
dim ds as double
dim pcoll as new pointcollection3d
sp=MyArc.StartParam
ep=MyArc.EndParam
ds=sp
Do While ds <= ep
 pcoll.add(Myarc.GetPointAtParam(ds)
 ds=ds+dp
Loop
Gaston Nunez
absStructural
Additionally, you could use GetPointAtDist(double distance) - depending on your exact needs.
in reply to: absStructural
thanks so much
”Boost
