.NET
Valued Contributor
hoathuongphuoc
Message 1 of 6 (235 Views)
How to determine collection point on ARC or circle
235 Views, 5 Replies
02-09-2014 10:37 PM
Hi All,
I have 1 problem, hope everybody can help me. This is, I have 1 arc and now i want to get all point on this arc.
I have attached image.
An arc is a curve class derived, so you can get points on the arc with something like this:
dim sp,ep as double
dim dp as double= 0.1 '<--Set this var to any value in order to obtain dense or sparse points
dim ds as double
dim pcoll as new pointcollection3d
sp=MyArc.StartParam
ep=MyArc.EndParam
ds=sp
Do While ds <= ep
pcoll.add(Myarc.GetPointAtParam(ds)
ds=ds+dp
Loop
Gaston Nunez
mzakiralam
Message 2 of 6 (207 Views)
Re: How to determine collection point on ARC or circle
02-10-2014 01:27 AM in reply to: hoathuongphuoc
HI,
Usually an arc consists of 3 points. Start, Center and End point. But from your picture it seems like that there is more than 3 points. can you clarify more regarding your problem?
Valued Contributor
hoathuongphuoc
Message 3 of 6 (202 Views)
02-10-2014 02:58 AM in reply to: mzakiralam
Yes, i can get 3 point(start,point,middle) but if i want to get any more point in arc. How can i do that. thanks for your help.
Distinguished Mentor
gasty1001
Message 4 of 6 (184 Views)
02-10-2014 07:30 AM in reply to: hoathuongphuoc
dim sp,ep as double
dim ds as double
sp=MyArc.StartParam
ep=MyArc.EndParam
ds=sp
Do While ds <= ep
 ds=ds+dp
Loop
Gaston Nunez
Active Contributor
absStructural
Message 5 of 6 (178 Views)
02-10-2014 08:20 AM in reply to: hoathuongphuoc
Additionally, you could use GetPointAtDist(double distance) - depending on your exact needs.
Valued Contributor
hoathuongphuoc
Message 6 of 6 (161 Views)
02-10-2014 06:16 PM in reply to: absStructural
thanks so much
