Hi Tony,
Thanks for the response.
As I'm rewriting a previous app I could change to managed at this point if i
wanted.
Is there a big advantage of one approach over the other in general, or are
some types of projects better in one than the other, or is com just a
temporary bridge til people rewire their brains to net?
if i convert i may just switch it to c# which seems a bit more popular than
vbnet
I did solve the problem just by checking if stringvar.trim.length = 0
why that worked when stringvar = "" or stringvar = " " didn't i don't know.
fwiw
Sub GetStringOrDefault(ByRef InputVariable As String, ByVal PromptString As
String, ByRef DefaultResponse As String)
Try
If DefaultResponse = "" Then
InputVariable = UCase(m_acadDoc.Utility.GetString(0, vbNewLine &
PromptString))
Else
PromptString & "<" & DefaultResponse & ">"))
End If
If InputVariable.Trim.Length = 0 Then
InputVariable = DefaultResponse
Else
DefaultResponse = InputVariable
End If
Catch ex As Exception
MsgBox("Invalid Input", MsgBoxStyle.Information, "")
InputVariable = "user must have cancelled?"
End Try
End Sub
see my response to your other replies if you'd like
thanks again
mark
"Tony Tanzillo" wrote in message
news:6293322@discussion.autodesk.com...
You may be using VB.NET but you're still using COM, so you would probably
get a faster answer in the VB.NET newsgroup, as this has little to do with
.NET or the managed API.
In fact, I can't even remember how that problem was solved, since its been
so long since I've used COM/ActiveX.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"mp" wrote in message
news:6293227@discussion.autodesk.com...
vb.net 2008 express
I want to request a string from user and store the response for next request
Then on subsequent requests if spacebar or enter is hit rather than a new
string, use the previous default.
tried the following but doesn't work
when the prompt asks for string, if i hit enter, program ends, instead of
using
preset default value and proceeding to next step
spacebar and enter don't seem to raise the exception, nor do the suceeding
if clauses catch an empty string
'at top of file to store user responses
private m_LasEntry as string
'then in middle of a command sequence:
Dim sEntry As String = ""
Try
If m_LasEntry = "" Then
sEntry = m_acadDoc.Utility.GetString(0, vbNewLine & "Enter something:")
Else
sEntry = m_acadDoc.Utility.GetString(0, vbNewLine & "Enter something :
m_LasEntry & ">")
End If
End Try
If sEntry = "" Then 'enter key was hit?
'accept default
sEntry = m_LastEntry
Exit Try
ElseIf sEntry = " " Then 'spacebar?
'accept default
Exit Try
End If
m_LastEntry = sEntry 'save entry for next default
any tips appreciated
mark
