Hello to everybody.
I'm using API.COM with Visual Studio 2008
My question is very simple, in VB6.0, VBA, etc. I declared an attribute variable like this:
Dim attr as variant
How i have to declare now in VB.net??
Thanks in advance.
Solved by celsoven. Go to Solution.
An attribute is an object in the AutoCAD.DatabaseServices namespace used in AutoCAD Blocks to hold text strings that can be modified after insertion. Do you mean that attribute, or just the old fashion, an attribute is a place holder for any data in code? For the latter Dim x as Object. "Object" is the 'anything goes' name for an empty variant.
jvj
I have this code
Dim blockCruce As Autodesk.AutoCAD.Interop.Common.AcadBlockReference
Dim Atributos As Object
Atributos = blockCruce.GetAttributes
atributos.TextString = "X= xxx"
'the blockCruce has an attribute i have to change the value to "X=xxx"
'but when i type atributos. doesn't show the method <<TextStrinh>> and I don't know why?
You are using the Attribute object as it is already inserted, so declare it like this:
Dim attr As Autodesk.AutoCAD.DatabaseServices.AttributeReference
jvj
Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.ApplicationServices Public Class Class1 <CommandMethod("getAtt")> _ Public Sub GetBlock() Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor() Dim sOptions As New PromptEntityOptions(vbCr & "Select Block: ") sOptions.SetRejectMessage(vbLf & "Invalid Selection: ") sOptions.AddAllowedClass(GetType(BlockReference), False) Dim sRes As PromptEntityResult = Nothing While (True) sRes = ed.GetEntity(sOptions) If Not sRes.Status <> PromptStatus.OK Then Getatt(sRes.ObjectId) Else Exit While End If End While End Sub Sub Getatt(ByVal objID As ObjectId) Using db As Database = HostApplicationServices.WorkingDatabase() Using tr As Transaction = db.TransactionManager.StartTransaction Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Using lock As DocumentLock = myDWG.LockDocument Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead, False) Dim bl As BlockReference = DirectCast(tr.GetObject(objID, OpenMode.ForRead), BlockReference) Dim AtCol As AttributeCollection = bl.AttributeCollection For Each AttID In AtCol Dim AtRef As AttributeReference = tr.GetObject(AttID, OpenMode.ForRead, False, True) MsgBox(AtRef.Tag & "-" & AtRef.TextString) Next AttID tr.Commit() End Using End Using End Using End Sub End Class netload
There have been a few replies to your question, but none of them is straight to your question. I am not questioning on why you use COM API instead of .NET API (if so, arcticad's repoly has detailed code for you to use) here, but you may want to make sure you do have good reason using COM API instead of .NET API.
Yes, in your case, you do declare
Because GetAttributes() method DOES NOT return an AcadAttributeRefernce object, rather it returns an Viriant (in COM API) or Object (in .NET it is equivelant to Variant in COM), which is an ARRAY of AcadAttributeReference object.
So, you cannot declare it as anything else but Object
The next line of code is wrong:
because atributos is an ARRAY of AcadAttributeReference object, not an AcadAttributeReference, thus, the array DOES NOT have a property "TextString". The code should be something like:
atributos(index).TextStriing="xxxxxx"
That is, only a specific element in the array is an AcadAttributeReference and has "TextString" property that you can get/set.
Again, make sure you have GOOD reason to use COM API.
I change the declaration to this:
Dim atributos As Autodesk.AutoCAD.DatabaseServices.AttributeReference
and now the program sends me the next error:
No se puede cargar el archivo o ensamblado 'acdbmgd, Version=17.0.51.0, Culture=neutral, PublicKeyToken=null' ni una de sus dependencias. El sistema no puede hallar el archivo especificado.
What could be the problem?
I change the declaration to:
Dim atributos As Object
and use it with and index like this
atributos(0).TextString = "X=" & insX(0)
and it works OK, but it runs slow, my program insert like 200 blocks and set the attribute to "X=1, X=2, X= 3, ... X= n
I don't know if I'm doing it on the correct way
Hello Norman
I'm using API.com because I learned with VB6.0 and is easier for me to use API.COM instead API.NET
I supose is better to use API.NET than API.COM but I don't know how to start wiht API.NET. it seems hard to learn isn't it?
Thanks a lot for your information.
If you need help in learning AutoCAD .Net API, you can download the AutoCAD .Net Labs and watch the DevTV from
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
The lab projects have code both in VB .Net and C#.
Hope this helps.
