.NET
How to ddd external references in the drawing? (C#)
1 REPLY 1
Sfinks7s
439 Views, 1 Reply
Hello, I want to load the external references in the drawing, how to implement this program?
I returned to the drawing path and the way I want to load it using the insertion point.
The code error is probably somewhere not understand where.
Please help )
[CommandMethod("TDMSXREF", CommandFlags.Session)]
publicvoid TDMSXREF()
   Document doc = Application.DocumentManager.MdiActiveDocument;
   Database db = doc.Database;
   Editor ed = doc.Editor;
   Transaction tr = db.TransactionManager.StartTransaction();
   using (tr)
      string path = "0";
      string moduleName = "CMD_SYSLIB";
      string functionName = "CheckOutSelObj";
      TDMSApplication tdmsAppDlg = newTDMSApplication();
      //path = tdmsAppDlg.ExecuteScript(moduleName, functionName);
      ObjectId xrefObj = db.AttachXref(@"C\MyD.dwg", "test");
      BlockReference br = newBlockReference(newPoint3d(0, 0, 0), xrefObj);
      BlockTable btTable =       (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
      BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(btTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
      modelSpace.AppendEntity(br);
      tr.AddNewlyCreatedDBObject(br, true);
      ed.WriteMessage(path);
   tr.Commit();
1 REPLY 1
fenton.webb
in reply to: Sfinks7s
don't call AttachXRef while inside a transaction, see if that solves your problem.
Fenton Webb
AutoCAD Engineering
”Boost
