.NET
Active Contributor
murali.pandey
Message 1 of 5 (1,061 Views)
How to create toolbar (C# objectArx)
1061 Views, 4 Replies
05-07-2012 03:22 AM
Hi
How ca I create a simple autocad map toolbar with one button with one button by using Dot net object arx(C#).
I do not want to use COM interface objects.
Murali
Moderator
Alexander.Rivilis
Message 2 of 5 (1,055 Views)
Re: How to create toolbar (C# objectArx)
05-07-2012 04:43 AM in reply to: murali.pandey
There are two ways:
1. COM - interface
2. CUI/CUIX - interface
Examples of both can be found on this forum.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
murali.pandey
Message 3 of 5 (1,028 Views)
05-07-2012 09:27 PM in reply to: Alexander.Rivilis
Would u pls send me the example (CUI based toolbar having one button).
Actually It is very tedious job 4 me to extract my interest of code.
Thanks a lot!
Murali
Moderator
Alexander.Rivilis
Message 4 of 5 (1,026 Views)
05-07-2012 09:40 PM in reply to: murali.pandey
Search CUISAMP
Active Contributor
murali.pandey
Message 5 of 5 (1,021 Views)
05-07-2012 10:48 PM in reply to: Alexander.Rivilis
Actually what I want to do is :
I have one dot net arx dll. I have to create a setup so that any autocad Map user can install it .After installing The user can load the dll. On loadng Toolbar with one button must be appear. If I do it with .mns file I have to hardcode the button icon path.
Murali
