I've followed a few examples and am able to create a new tab on the Ribbon, with panels and buttons, that appears when my DLL is loaded. However, it doesn't persist through workspace changes. I've read that this is due to my use of AdWindows.dll and my current code, as opposed to AcCui.dll, which would modify a CUIx file (that I don't know much about) to make persistant changes.
Does anyone know of examples of this? I've searched around and haven't seen them.
Here is a sample of my current code.
public class Commands : Autodesk.AutoCAD.Runtime.IExtensionApplication { public void Initialize() { Application.Idle += callback_Idle; } private void callback_Idle(Object sender, EventArgs e) { CreateRibbon(); Application.Idle -= callback_Idle; } private void CreateRibbon() { RibbonControl mainAcadRibbon = ComponentManager.Ribbon; if (mainAcadRibbon != null) { RibbonTab rTab = mainAcadRibbon.FindTab("Tab Name"); if (rTab != null) { mainAcadRibbon.Tabs.Remove(rTab); } rTab = new RibbonTab(); rTab.Title = "Title"; rTab.Id = "ID"; mainAcadRibbon.Tabs.Add(rTab); addPanelsToRibbon(rTab); } } static void addPanelsToRibbon(RibbonTab rtab) { rtab.Panels.Add(panelExample()); } static RibbonPanel panelExample() { RibbonButton rb1; RibbonButton rb2; RibbonPanelSource rps = new RibbonPanelSource(); rps.Title = "Title"; RibbonPanel rp = new RibbonPanel(); rp.Source = rps; rb1 = new RibbonButton(); rb1.Name = "Name1"; rb1.ShowText = true; rb1.Text = "Text1"; rb1.CommandHandler = new RibbonCommandHandler(); rps.Items.Add(rb1); rb2 = new RibbonButton(); rb2.Name = "Name2"; rb2.ShowText = true; rb2.Text = "Text2"; rb2.CommandHandler = new RibbonCommandHandler(); rps.Items.Add(rb2); return rp; } public class RibbonCommandHandler : System.Windows.Input.ICommand { public bool CanExecute(object parameter) { return true; } // CanExecuteChanged must be implemented, even if not used. public event EventHandler CanExecuteChanged; public void Execute(object parameter) { Document doc = Application.DocumentManager.MdiActiveDocument; if (parameter is RibbonButton) { try { switch (button.Name.ToString()) { case "Name1": break; case "Name2": break; default: break; } } catch (Autodesk.AutoCAD.Runtime.Exception ex) { Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString()); } catch (System.NullReferenceException ex) { Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString()); } } } } }
Can you please say wheere you are getting those ribbon controls from? I included the accui.dll in the project and got rid of some of the errors but am having a problem finding where these are coming from...
Autodesk.AutoCAD.???...ComponentManager.Ribbon
Thanks for that help. I got stuck on one more item if you wouldn't helping with that too. Am compiling to dll. Impossible to debug.
OK that did the trick. Thanks for the code. I converted it to VB but have not tested yet. Here it is.
include acwindows.dll & accui.dll Imports Autodesk.AutoCAD.Customization Imports Autodesk.Windows Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize AddHandler Application.Idle, AddressOf callback_Idle End Sub Private Sub callback_Idle(ByVal sender As [Object], ByVal e As EventArgs) CreateRibbon() RemoveHandler Application.Idle, AddressOf callback_Idle End Sub Private Sub CreateRibbon() Dim mainAcadRibbon As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon ' ComponentManager.Ribbon If mainAcadRibbon IsNot Nothing Then Dim rTab As RibbonTab = mainAcadRibbon.FindTab("Tab Name") If rTab IsNot Nothing Then mainAcadRibbon.Tabs.Remove(rTab) End If rTab = New RibbonTab() rTab.Title = "Title" rTab.Id = "ID" mainAcadRibbon.Tabs.Add(rTab) addPanelsToRibbon(rTab) End If End Sub Private Shared Sub addPanelsToRibbon(ByVal rtab As RibbonTab) rtab.Panels.Add(panelExample()) End Sub Private Shared Function panelExample() As RibbonPanel Dim rb1 As Autodesk.Windows.RibbonButton Dim rb2 As Autodesk.Windows.RibbonButton Dim rps As New Autodesk.Windows.RibbonPanelSource() rps.Title = "Title" Dim rp As New RibbonPanel() rp.Source = rps rb1 = New Autodesk.Windows.RibbonButton() rb1.Name = "Name1" rb1.ShowText = True rb1.Text = "Text1" rb1.CommandHandler = New RibbonCommandHandler() rps.Items.Add(rb1) rb2 = New Autodesk.Windows.RibbonButton() rb2.Name = "Name2" rb2.ShowText = True rb2.Text = "Text2" rb2.CommandHandler = New RibbonCommandHandler() rps.Items.Add(rb2) Return rp End Function Public Class RibbonCommandHandler 'Implements System.Windows.Input.ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Return True End Function ' CanExecuteChanged must be implemented, even if not used. Public Event CanExecuteChanged As EventHandler Public Sub Execute(ByVal parameter As Object) Dim doc As Document = Application.DocumentManager.MdiActiveDocument If TypeOf parameter Is Autodesk.Windows.RibbonButton Then Dim button As Autodesk.Windows.RibbonButton = TryCast(parameter, Autodesk.Windows.RibbonButton) Try Select Case button.Name.ToString() Case "Name1" Exit Select Case "Name2" Exit Select Case Else Exit Select End Select Catch ex As Autodesk.AutoCAD.Runtime.Exception Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString()) Catch ex As System.NullReferenceException Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString()) End Try End If End Sub End Class
