.NET
.NET
New Member
autocadfresher
Message 1 of 3 (376 Views)
how to create an ole object with Ole2frame
376 Views, 2 Replies
10-24-2011 08:08 PM
i want to create an ole object linked with a bmp file.but when i create the ole2frame object with the code "ole2frame obj = new ole2frame();",i don't know what to do next.can anybody help me?
Member
kıeslowskı
Message 2 of 3 (278 Views)
Re: how to create an ole object with Ole2frame
08-07-2012 10:45 AM in reply to: autocadfresher
Hi
We need a create an OLE OBJECT  Source Code. Do you have ?
ADN Support Specialist
Balaji_Ram
Message 3 of 3 (250 Views)
08-10-2012 02:54 AM in reply to: kıeslowskı
I had replied to your other post on the same topic.
It is not possible for applications to create an ole object (AcDbOle2Frame/Ole2Frame object) in AutoCAD.
This is explained in the ObjectARX help file in the description for “setOleObject” method and I quote :
“The COleClientItem class used by AutoCAD is a modified version of the class that ships from Microsoft. This means that it is not possible for applications to create their own COleClientItem objects for use by this function. This function can only be used with COleClientItem objects created by AutoCAD (that is, the object from another AcDbOle2Frame object).“
For this reason, the workaround could be to use a drawing file that contains the image as a template and using it in an insert operation.
If it is just an image in the drawing that you want to insert (not a Ole2Frame), you may find this blog post helpful :
http://adndevblog.typepad.com/autocad/2012/05/how-to-insert-a-rasterimage-using-the-net-api.html
Balaji
Developer Technical Services
Autodesk Developer Network
