.NET
How to create a block with a Att for display path of Xref
1 REPLY 1
AubelecBE
248 Views, 1 Reply
Hi all.
i looking a way for create a block after selected a Xref.
It is for display the path+Name of my Xref.
It use fields manualy put i can copy/paste the bloc. (ObjectId not egual in a 2 dwg).
I want :
1 - selec the Xref --> I know how to do that.
2 - create a bloc --> I know.
3 - create a att -> i know
4 - fill the att with the field --> ???
can you help me ?
1 REPLY 1
_gile
in reply to: AubelecBE
There was some thread about using Fields in AutoCAD DevBlog.
Assuming attRef is the attribute reference instance and xrefId the xref ObjectId (not tested):
attRef.TextString = String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%).Path>%", xrefId.OldIdPtr)
Gilles Chanteau
GileCAD
GitHub
”Boost
