.NET
How to copy blocks using VB.NET through COM?
12 REPLIES 12
Message 1 of 13
taiven
1732 Views, 12 Replies
Hi, all:
I got a question about access AUTOCAD through COM.
Previously I have one VB6 program, which read blocks from an external dwg files and insert into AUTOCAD2010's activepage.
Now I want to upgrade to VB.NET2010, but found one big problem cannot be resolved, that is, how to copy blocks from an external dwg files?
I use the command below to copy blocks from dwg file:
Call GetBlocksFromDwg("d:\abc.dwg", obj_Doc)
obj_'s definition is:
Dim obj_Doc As Autodesk.AutoCAD.Interop.AcadDocument
Previous VB6 source codes:
Private Sub GetBlocksFromDwg(DwgName As String, Target As Object)
Set DbxDoc = obj_Acad.GetInterfaceObject("ObjectDBX.AxDbDocument.18")
DbxDoc.Open DwgName
Dim Objects(0 To 0) As Object
For Each entry In DbxDoc.Blocks
    Set Objects(0) = DbxDoc.Blocks(entry.Name)
    DbxDoc.CopyObjects Objects, Target.Blocks
Next
End Sub
Current VB.NET 2010's source codes:
Private Sub GetBlocksFromDwg(ByRef DwgName As String, ByRef Target As Object)
Dim entry As Object
Dim DbxDoc As Object
DbxDoc.Open(DwgName)
Dim Objects(0) As Object
  CopyObjects(Objects, Target.Blocks, Type.Missing)
Next entry
End Sub
The command below cannot work:
Please advise, thanks a lot.
12 REPLIES 12
Message 2 of 13
Alfred.NESWADBA
in reply to: taiven
>>>there<<< you find a sample for .NET (I would prefere that instead of COM)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
taiven
in reply to: taiven
Hi, Alfred:
The problem is I composed an application EXE to access AutoCAD, so COM is the only method.
Message 4 of 13
Alfred.NESWADBA
in reply to: taiven
my method of an EXE would be to just start AutoCAD, then load my DLL and let the DLL do the work 😉
But let's see if someone is coming with a ready COM-code.
- alfred -
Alfred NESWADBA
Message 5 of 13
taiven
in reply to: Alfred.NESWADBA
Yeah, hoping someone can resolve the problem.
Message 6 of 13
Alfred.NESWADBA
in reply to: taiven
Have not tried that, but why did you change the VB6-Code from that line when converting?
DbxDoc.CopyObjects(Objects, Target.Blocks, Type.Missing)
What error message do you get?
- alfred -
Alfred NESWADBA
Message 7 of 13
taiven
error message: invalid object array
Message 8 of 13
Alfred.NESWADBA
in reply to: taiven
you get this message with both versions of code?
BTW: what version of AutoCAD do you use?
- alfred -
Alfred NESWADBA
Message 9 of 13
taiven
is converted to
DbxDoc.CopyObjects(Objects, Target.Blocks)
and
CopyObjects(Objects, Target.Blocks, Type.Missing) is illegal.
I use AutoCAD 2010, with VB.net 2010.
Message 10 of 13
taiven
in reply to: taiven
Just add some test codes.
you may copy aaa.dwg to c:\, or just change the location for the dwg file.
thanks.
Message 11 of 13
Alfred.NESWADBA
in reply to: taiven
I tried it that way and it worked (with a button in the form), I hope for you too 😉
   Const tSourceFileName As String = "C:\TEMP\X01.DWG"
   Const tDestFileName As String = "C:\TEMP\X02.DWG"
   Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
      Dim obj_Acad As AcadApplication = CType(GetObject(, "AutoCAD.Application.18"), AcadApplication)
      Dim TargetDoc As AcadDocument = obj_Acad.Documents.Open(tDestFileName)
      Dim DbxDoc As Object = obj_Acad.GetInterfaceObject("ObjectDBX.AxDbDocument.18")
      DbxDoc.Open(tSourceFileName)
      Dim Objects(0) As Common.AcadBlock
      For Each entry As Common.AcadBlock In CType(DbxDoc.Blocks, IEnumerable)
         If (Not entry.IsLayout) AndAlso (Not entry.Name.StartsWith("*")) Then
            Objects(0) = entry
            DbxDoc.CopyObjects(CObj(Objects), TargetDoc.Blocks)
            Debug.Print(entry.Name)
      Next entry
   End Sub
- alfred -
Alfred NESWADBA
Message 12 of 13
taiven
Hi, Alfred:
Thanks a lot, it works.
The key is:
dim entry as acadblock
dim Objects(0) as acadblock
Objects(0)=entry
Fantastic!
Thanks.
Message 13 of 13
murugasubi
in reply to: taiven
Hi. I am trying to copy a entity from one document to another. but not copying.
This is my code.
Autocad:2014, .net-2010
Public AcadApp As AutoCAD.AcadApplication
Public SourceDoc As AutoCAD.AcadDocument
Public DestDoc As AutoCAD.AcadDocument
AcadApp = CreateObject("AutoCAD.Application")
Dim circleObj1 As AutoCAD.AcadCircle
Dim circleObj2 As AutoCAD.AcadCircle
Dim centerPoint(0 To 2) As Double
Dim objCollection(0 To 1) As Object
centerPoint(0) = 0.0# : centerPoint(1) = 0.0# : centerPoint(2) = 0.0#
circleObj1 = SourceDoc.ModelSpace.AddCircle(centerPoint, 5)
circleObj2 = SourceDoc.ModelSpace.AddCircle(centerPoint, 10)
objCollection(0) = circleObj1
objCollection(1) = circleObj2
DestDoc = AcadApp.Documents.Add("Destination.dwg")
DestDoc = AcadApp.ActiveDocument
Dim destEnts As Object
destEnts = SourceDoc.CopyObjects(objCollection, DestDoc.ModelSpace)
'two circles drawn in soruce document-
'destination document opend.
but not copying. values in destents is nothing.
pls. help
”Boost
