.NET
how to copy block from an unopened docment?
6 REPLIES 6
394 Views, 6 Replies
I tried many times and use several method to copy a block in an unopened file to current document. com method is ok,but net arx method always failed .who can help me and post a sample of net arx.
the following is my code of arx method
private static ObjectId GetBlockArx(string blockFile, String name )
ObjectId block = ObjectId.Null;
Database db = new Database();
db.ReadDwgFile(blockFile, System.IO.FileShare.Read, false, null);
ArrayList list = new ArrayList();
Transaction dbTrans = db.TransactionManager.StartTransaction();
try
BlockTable dbbt = dbTrans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord dbBtr = dbTrans.GetObject(dbbt[name], OpenMode.ForRead) as BlockTableRecord;
foreach (ObjectId entId in dbBtr)
Entity ent = dbTrans.GetObject(entId, OpenMode.ForRead) as Entity;
Entity newEnt = ent.Clone() as Entity;
list.Add(newEnt);
dbTrans.Commit();
finally
dbTrans.Dispose();
db.Dispose();
Transaction trans = Arx.Tm.StartTransaction();
try
BlockTable bt = trans.GetObject(Arx.Db.BlockTableId, OpenMode.ForWrite) as BlockTable;
foreach (ObjectId idd in bt)
BlockTableRecord btrr = trans.GetObject(idd, OpenMode.ForWrite) as BlockTableRecord;
if (btrr.Name.ToUpper() == name.ToUpper())
btrr.Erase();
BlockTableRecord newBtr = new BlockTableRecord();
newBtr.Name = name;
block = bt.Add(newBtr);
trans.AddNewlyCreatedDBObject(newBtr, true);
foreach (object obj in list)
newBtr.AppendEntity(obj as Entity);
trans.AddNewlyCreatedDBObject(obj as Entity, true);
foreach (ObjectId nentId in newBtr)
Entity nent = trans.GetObject(nentId, OpenMode.ForRead) as Entity;
trans.Commit(); // a fatal error here
finally { trans.Dispose(); }
return block;
6 REPLIES 6
Mikko
Here is a VB example based on what was posted by Albert Szilvasy.
<CommandMethod("BlkTest")> _
Public Sub blkTest()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim tr As Transaction = doc.TransactionManager.StartTransaction
Try
Dim dwgName As String = HostApplicationServices.Current.FindFile("C:\temp\myLines.dwg", Application.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default)
Dim db As Database = New Database(False, False)
db.ReadDwgFile(dwgName, IO.FileShare.Read, True, "")
Dim NewBlkId As ObjectId
NewBlkId = doc.Database.Insert(dwgName, db, False)
Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, True)
Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, True)
Dim bref As BlockReference = New BlockReference(New Point3d(0.0, 0.0, 0.0), NewBlkId)
btr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
tr.Commit()
Catch ex As Exception
ed.WriteMessage(ex.ToString)
End Try
End Sub
what I mean is to insert a block in an unopened drawing to current drawing, not to insert an unopened drawing as a block to current drawing.
Mikko
myTest.dwg has a block called circles in it.
<CommandMethod("blkInblk")> _
Public Sub blkInblk()
Try
Dim dwgName As String = HostApplicationServices.Current.FindFile("C:\temp\myTest.dwg", Application.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default)
Dim takeBlkId As ObjectId
Dim tbt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForWrite)
If (tbt.Has("Circles")) Then
takeBlkId = tbt("Circles")
Else
ed.WriteMessage("This aint happening")
Exit Sub
End If
Dim bref As BlockReference = New BlockReference(New Point3d(0.0, 0.0, 0.0), takeBlkId)
tr.Commit()
Finally
tr.Dispose()
End Try
End Sub
Mikko
After looking at this a bit more, I find I get an fatal error when trying to reopen the drawing.
Realised I didn't write the block definition so I revised the code somewhat but I'm still getting
a fatal error.
Dim bibId As ObjectId
Try
Else
Exit Sub
End If
Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForWrite, True)
Dim newBTR As BlockTableRecord = New BlockTableRecord
newBTR.Name = "Circles"
bibId = bt.Add(newBTR)
tr.AddNewlyCreatedDBObject(newBTR, True)
newBTR.AppendEntity(bref)
tr.Commit()
Finally
tr.Dispose()
End Try
End Sub
FATAL ERROR: Unhandled Access Violation Reading 0x0019 Exception at 648fefd 1h
Anybody see my error?
my friend .i have the same problem with you .have you firgured oot the solution.
please tell me if you have got it .
jbooth
Attached is a snippet that I have had no issues with.
What I did was use wblock to map a clone of the blocktable's entities from an external drawing database into the active database. If the external drawing didn't have a matching blocktable, the modelspace table is used instead as a default.
ps: I wrote this function two years ago. it may not be correctly disposing the AcDb objects it uses, so be aware of that if you plan to copy/paste it into your code. Also, it's in VB.NET so if you want to use it, you will have to translate it into C#.
”Boost
