I want to transfer a layout from an existing drawing.
But i have an error:
epermanentlyerased
fails at:
DB_template.WblockCloneObjects(Id_colection, Database1.LayoutDictionaryId,
New IdMapping(), DuplicateRecordCloning.Replace, False)
I read about wblockclone in this forum but I couldn't get it to work.
Can somebody help me?
PrivateSub test()
TryDim Current_drawing AsDocument = Application.DocumentManager.MdiActiveDocument
Dim Drawing_Template_location AsString= "c:\drawing_template.dwg"
Dim DB_template AsNewDatabase
Dim Numele_template_layout AsString= "Template_layout"
Dim Id_Layout_t AsObjectId
Dim Id1 AsObjectId
Using Lock1 AsDocumentLock = Current_drawing.LockDocument
Dim Database1 AsDatabase = Current_drawing.Database
Dim TransManag1 AsAutodesk.AutoCAD.DatabaseServices.TransactionManager = Database1.TransactionManager
Using Trans1 AsTransaction = Database1.TransactionManager.StartTransaction
Using Trans2 AsTransaction = DB_template.TransactionManager.StartTransaction
DB_template.ReadDwgFile(Drawing_Template_location, FileOpenMode.OpenForReadAndAllShare,True, "")
Id1 = DB_template.LayoutDictionaryId
Dim Layoutdict As DBDictionary = Trans2.GetObject(Id1, OpenMode.ForRead, False, False)
ForEach entry As DBDictionaryEntry InLayoutdict
If entry.Key = Numele_template_layout Then
Id_Layout_t = entry.Value
ExitForEndIfNextIf Id_Layout_t <> ObjectId.Null Then
Dim Id_colection AsNewObjectIdCollection
Id_colection.Add(Id_Layout_t)
Trans1.Commit()
EndIf
EndUsing
EndUsing
EndUsing
Catch ex AsException
MsgBox(ex.Message)
EndTry
EndSub
http://www.theswamp.org/index.php?topic=37443.msg424943#msg424943
