.NET
Showing results forĀ
Did you mean:Ā
How to control the color the of the contents in the command prompt?
2 REPLIES 2
HelloWorlddd
370 Views, 2 Replies
Sometimes, I need to output some warning message to users, there will be several messages, if I use the message box, it's unfriendly, so ,I want output all warning message in the command prompt, but it's not marked.,but I don't know how to set the color.
For example, the message show in the command prompt will be like below:
Warning:
xxxx xxx xxx xxx .............
What's the usual way of output the error, warning or exception, Any help much appreciated.
2 REPLIES 2
mzakiralam
in reply to: HelloWorlddd
you can control the command line Background Color, command line text size, font and style from Options but not a particular string in command line
HelloWorlddd
in reply to: mzakiralam
Thanks for your help. Maybe I should try some others ways to output warning.
ā€Boost
