.NET
.NET
Valued Mentor
AubelecBE
Message 1 of 4 (228 Views)
How to check if a drawving is saved
228 Views, 3 Replies
01-23-2014 03:30 AM
Hi all.
i want to check if my file is saved or not. (already named). I need to do this for launch the command "-etransmit"
but i dont know how to do that.
No global var and found nothing here.
Thanks for your help.
If you check 'DBMOD' system variable, you can get the drawing modification status. Below is the sample code to check if drawing has been saved or not.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
<CommandMethod("DrawingSaved")> _
Public Sub DrawingSaved()
Dim obj As Object = Application.GetSystemVariable("DBMOD")
'' Check the value of DBMOD, if 0 then the drawing has not been changed
If Not (System.Convert.ToInt16(obj) = 0) Then
If MsgBox("Do you wish to save this drawing?", _
MsgBoxStyle.YesNo, _
"Save Drawing") = MsgBoxResult.Yes Then Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
acDoc.Database.SaveAs(acDoc.Name, True, DwgVersion.Current, _
acDoc.Database.SecurityParameters) End If End If End Sub
You can find details about DBMOD variable in below location:
http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-50a8.htm
Distinguished Mentor
gasty1001
Message 2 of 4 (212 Views)
Re: How to check if a drawving is saved
01-23-2014 05:50 AM in reply to: AubelecBE
I think a combination of "DWGTITLED" and "DBMOD" system variables  should provide you the information needed to etransmit or to not etransmit.
Gaston Nunez
mzakiralam
Message 3 of 4 (196 Views)
01-23-2014 08:07 AM in reply to: AubelecBE
http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-50a8...
Valued Mentor
AubelecBE
Message 4 of 4 (162 Views)
01-24-2014 03:20 AM in reply to: mzakiralam
Thanks, work fine.
