.NET
.NET
Active Member
chi_nm
Message 1 of 6 (188 Views)
How to check dashed line when project all edges of faces to a plane.
188 Views, 5 Replies
06-14-2013 02:44 AM
I have some faces and i want project them to xy plane (Top view).
I want to get exterior boundary line of this model. To do this, i will ignore all dashed lines, but i cannot check a line is dashed line or not.
Please help me!
ADN Support Specialist
philippe.leefsma
Message 2 of 6 (160 Views)
Re: How to check dashed line when project all edges of faces to a plane.
06-18-2013 06:35 AM in reply to: chi_nm
It is not clear to me what is it that you call dashed lines? Are those lines the ones that are supposed to be hidden as a result of the projection or are they actually dashed because of their linetype for example?
In order to project entities and remove hidden lines, you need to rely on the Hidden Line Removal API: check the ObjectARX %VERSION%\utils\HlrApi sample for more details.
Hope it helps.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Active Member
chi_nm
Message 3 of 6 (142 Views)
06-20-2013 12:23 AM in reply to: philippe.leefsma
Thanks leefsma,
i want check a line is hidden line in set of lines (after project them to a plane)
you can see attachment image to detail.
philippe.leefsma
Message 4 of 6 (132 Views)
06-20-2013 12:59 AM in reply to: chi_nm
You need to use HLR API then.
Philippe.
Philippe Leefsma
Active Member
chi_nm
Message 5 of 6 (128 Views)
06-20-2013 02:01 AM in reply to: philippe.leefsma
Can I use HLR API in .Net?
Please give me an example.
philippe.leefsma
Message 6 of 6 (123 Views)
06-20-2013 02:13 AM in reply to: chi_nm
Nope, this API is only available in C++ with the sample I mentionned previously. If you want to invoke it from .Net, you would need to write your own mixed-managed wrapper for it.
Philippe.
Philippe Leefsma
