.NET
Valued Mentor
AubelecBE
Message 1 of 4 (303 Views)
How to check BlockReference
303 Views, 3 Replies
01-03-2013 03:54 AM
HI all.
So i have 3 file DWG :
3.dwg : is a plan 'archi'
2.dwg is a plan with only décoration.
1. dwg is a plan with only the water.
i have this structure in my file (1.dwg) :
1.dwg
---> 2..dwg
---------> 3.dwg   (this file is a Xref of 2.dwg)
--> is the blockRefecence (XRef).
my code :
        Dim CollXref As New ObjectIdCollection
        Dim mydb As Database = Application.DocumentManager.MdiActiveDocument.Database
        Dim myTrans As Transaction = mydb.TransactionManager.StartTransaction
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim DocLock As DocumentLock = doc.LockDocument
        Try
            Dim BlocTable As BlockTable = CType(myTrans.GetObject(mydb.BlockTableId, OpenMode.ForRead), BlockTable)
            For Each btid As ObjectId In BlocTable
                Dim DefBloc As BlockTableRecord = CType(myTrans.GetObject(btid, OpenMode.ForWrite), BlockTableRecord)
                If DefBloc.IsFromExternalReference = True Then
                    If DefBloc.IsResolved = False Then
                    Else
                        CollIdXref.Add(btid)
                    End If
                End If
            Next
            myTrans.Commit()
        Catch ex As Exception
            MsgBox(ex.Message, vbOKOnly & vbCritical, "ee")
        Finally
            myTrans.Dispose()
        End Try
        DocLock.Dispose()
        DocLock = Nothing
So i don't want to add Id of a Xref From a Xref. (In my example i want only ObjectId of the 2.dwg not 3.dwg if i launch this code on 1.dwg.
How i can do that ?
Here my code final :
 Dim LockDoc As DocumentLock = doc.LockDocument
Dim OkErr as boolean = false
Dim CollXRef As New ObjectIdCollection
Do
CollXRef.Clear()
Dim xg As XrefGraph = db.GetHostDwgXrefGraph(True)
Dim root As GraphNode = xg.RootNode
Using tr As Transaction = db.TransactionManager.StartTransaction
For o = 0 To root.NumOut - 1 Step 1
Dim child As XrefGraphNode = CType(root.Out(o), XrefGraphNode)
If child.XrefStatus = XrefStatus.Resolved Then
Dim bl As BlockTableRecord = tr.GetObject(child.BlockTableRecordId, OpenMode.ForRead)
'ed.WriteMessage(vbCrLf & i_indent + child.Database.Filename)
' Name of the Xref (found name)
' You can find the original path too:
If bl.IsFromExternalReference = True Then
ed.WriteMessage(vbCrLf & "Xref path name: " + bl.PathName)
CollXRef.Add(bl.ObjectId)
Exit For
End If
End If
Next
'trouvé un xref --> Adding
If CollXRef.Count > 0 Then
Try
doc.Database.BindXrefs(CollXRef, False)
okErr = True
MsgBox("Erreur lors de la liaison d'un Xref" & vbCrLf & "--> Essayer de lier le premier niveau", _
vbOKOnly & vbCritical, _
"Erreur Système")
Finally
tr.Commit()
End Try
End If
End Using
ed.WriteMessage(vbCrLf & "-> " & CollXRef.Count.ToString)
Loop Until (CollXRef.Count = 0) Or (okErr = True)
LockDoc.Dispose()
LockDoc = Nothing
 If check only one XRef. it is for the binf of only one XREF.
I have big file to bing and if i bing all in one troke, autocad crack for a 'Out of mémory'
I can't check it now (i am not on my work). So i don't know if i have resolve this case of out of memory.
Member
gopinatht
Message 2 of 4 (266 Views)
Re: How to check BlockReference
01-04-2013 02:14 PM in reply to: AubelecBE
You can use the XRef Graph to determine if an XRef is nested. Here is a blog post that shows how to use the XRefGraph type:
http://adndevblog.typepad.com/autocad/2012/06/finding-all-xrefs-in-the-current-database-using-cnet.h...
Cheers
Gopinath
Valued Mentor
AubelecBE
Message 3 of 4 (247 Views)
01-05-2013 02:56 AM in reply to: gopinatht
Thx i have to see that
Valued Mentor
AubelecBE
Message 4 of 4 (222 Views)
01-06-2013 02:43 AM in reply to: AubelecBE
                Do
                    CollXRef.Clear()
                                    Exit For
                                End If
                            End If
                        Next
                            Try
                                okErr = True
                                              "Erreur Système")
                            Finally
                                tr.Commit()
                            End Try
                        End If
                    End Using
                LockDoc.Dispose()
                LockDoc = Nothing
