Hi all i have a VBA code for check and choose unit but how i can in .NET ?
Unite = ThisDrawing.GetVariable("INSUNITS") Select Case Unite Case 4: Unite = 10 'mm Case 5: Unite = 1 'cm Case 6: Unite = 0.01 'm Case Else: Unite = 1 End Select
i dont find help for this..
db.UnitMode is always = 0
i have try this :
Dim BlocT As BlockTable Dim tr As Transaction = db.TransactionManager.StartTransaction BlocT = tr.GetObject(db.BlockTableId, OpenMode.ForRead) Dim Bloc As BlockTableRecord Bloc = tr.GetObject(BlocT(BlockTableRecord.ModelSpace), OpenMode.ForRead) Dim lay As Layout = tr.GetObject(Bloc.LayoutId, OpenMode.ForRead) tr.Commit() tr.Dispose()
but bloc.units dont egal the unit command in autocad.
I can use :
Dim obj As Object = Application.GetSystemVariable("INSUNITS")
but i want a proper solution with .net.
anyone can help ?
Solved by Alexander.Rivilis. Go to Solution.
Database.Insunits ?
Facebook | Twitter | LinkedIn
