.NET
.NET
Valued Mentor
29 Kudos
Post 1 of 2
How to check and manage Unit for insert a BlockReference
163 Views, 1 Replies
02-26-2012 10:38 AM
Hi all i have a VBA code for check and choose unit but how i can in .NET ?
    Unite = ThisDrawing.GetVariable("INSUNITS")
    Select Case Unite
      Case 4: Unite = 10 'mm
      Case 5: Unite = 1   'cm
      Case 6: Unite = 0.01   'm
      Case Else: Unite = 1
    End Select
 i dont find help for this..
db.UnitMode is always = 0
i have try this :
Dim BlocT As BlockTable
        Dim tr As Transaction = db.TransactionManager.StartTransaction
        BlocT = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
        Dim Bloc As BlockTableRecord
        Bloc = tr.GetObject(BlocT(BlockTableRecord.ModelSpace), OpenMode.ForRead)
        Dim lay As Layout = tr.GetObject(Bloc.LayoutId, OpenMode.ForRead)
        tr.Commit()
        tr.Dispose()
 but bloc.units dont egal the unit command in autocad.
I can use  :
Dim obj As Object = Application.GetSystemVariable("INSUNITS")
but i want a proper solution with .net.
anyone can help ?
Moderator
277 Kudos
Post 2 of 2
Re: How to check and manage Unit for insert a BlockReference
02-26-2012 11:45 AM in reply to: AubelecBE
Database.Insunits ?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
