.NET
How to change the 'Window command' color
4 REPLIES 4
_gile
723 Views, 4 Replies
I need to programmatically change the 'Window command' (Commande de fenĂȘtre in French) color. I didn't find anything in Application.Preferences neither in the registry.
Has anybody a solution ?
Thanks.
By 'Window command' I'm talking about the feature comming with A2012 displayed in the upper left corner of model space windows:
Gilles Chanteau
GileCAD
GitHub
4 REPLIES 4
Alexander.Rivilis
in reply to: _gile
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\RXX.X\ACAD-YYYY:ZZZ\FixedProfile\Editor Configuration
2D Model viewport control color
Parallel viewport control color
Perspective viewport control color
Đ’Ń–ĐŽĐżĐŸĐČіЮь ĐșĐŸŃ€ĐžŃĐœĐ°? КліĐșĐœŃ–Ń‚ŃŒ ĐœĐ° "ВПОДОБАЙКУ" Ń†Ń–ĐŒ ĐżĐŸĐČŃ–ĐŽĐŸĐŒĐ»Đ”ĐœĐœŃĐŒ! | Do you find the posts helpful? "LIKE" these posts!
ĐĐ°Ń…ĐŸĐŽĐžŃ‚Đ” ŃĐŸĐŸĐ±Ń‰Đ”ĐœĐžŃ ĐżĐŸĐ»Đ”Đ·ĐœŃ‹ĐŒĐž? ĐŸĐŸŃŃ‚Đ°ĐČŃŒŃ‚Đ” "НРАВИбСЯ" ŃŃ‚ĐžĐŒ ŃĐŸĐŸĐ±Ń‰Đ”ĐœĐžŃĐŒ!
На ĐČашД Đ·Đ°ĐżĐžŃ‚Đ°ĐœĐœŃ ĐČŃ–ĐŽĐżĐŸĐČілО? ĐĐ°Ń‚ĐžŃĐœŃ–Ń‚ŃŒ ĐșĐœĐŸĐżĐșу "ПРИЙНЯбИ РІйЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ĐČаш ĐČĐŸĐżŃ€ĐŸŃ ŃƒŃĐżĐ”ŃˆĐœĐŸ ĐŸŃ‚ĐČДтОлО? ĐĐ°Đ¶ĐŒĐžŃ‚Đ” ĐșĐœĐŸĐżĐșу "УбВЕРДИбЬ РЕйЕНИЕ"
Alexander Rivilis / АлДĐșŃĐ°ĐœĐŽŃ€ Đ ĐžĐČОлОс / ОлДĐșŃĐ°ĐœĐŽŃ€ РіĐČіліс
Programmer & Teacher & Helper / ĐŸŃ€ĐŸĐłŃ€Đ°ĐŒĐŒĐžŃŃ‚ - ĐŁŃ‡ĐžŃ‚Đ”Đ»ŃŒ - ĐŸĐŸĐŒĐŸŃ‰ĐœĐžĐș / ĐŸŃ€ĐŸĐłŃ€Đ°ĐŒŃ–ŃŃ‚ - ĐČŃ‡ĐžŃ‚Đ”Đ»ŃŒ - ĐżĐŸĐŒŃ–Ń‡ĐœĐžĐș
Facebook | Twitter | LinkedIn
Expert Elite Member
_gile
in reply to: Alexander.Rivilis
Thank you very much Alexander.
Gilles Chanteau
GileCAD
GitHub
Alexander.Rivilis
in reply to: _gile
Another way is P/Invoke acedGetCurrentColorsEx3/acedSetCurrentColorsEx3 function:
    /* Viewport control for various contexts */
    DWORD dw2DModelVportControl;
    DWORD dwParallelVportControl;
    DWORD dwPerspectiveVportControl;
Expert Elite Member
_gile
Thanks, I finally solve it P/Invoking acedSetenv.
Gilles Chanteau
GileCAD
GitHub
”Boost
