.NET
How to change the 'Window command' color
4 REPLIES 4
_gile
721 Views, 4 Replies
I need to programmatically change the 'Window command' (Commande de fenêtre in French) color. I didn't find anything in Application.Preferences neither in the registry.
Has anybody a solution ?
Thanks.
By 'Window command' I'm talking about the feature comming with A2012 displayed in the upper left corner of model space windows:
Gilles Chanteau
GileCAD
GitHub
4 REPLIES 4
Alexander.Rivilis
in reply to: _gile
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\RXX.X\ACAD-YYYY:ZZZ\FixedProfile\Editor Configuration
2D Model viewport control color
Parallel viewport control color
Perspective viewport control color
Facebook | Twitter | LinkedIn
Expert Elite Member
_gile
in reply to: Alexander.Rivilis
Thank you very much Alexander.
Gilles Chanteau
GileCAD
GitHub
Alexander.Rivilis
in reply to: _gile
Another way is P/Invoke acedGetCurrentColorsEx3/acedSetCurrentColorsEx3 function:
    /* Viewport control for various contexts */
    DWORD dw2DModelVportControl;
    DWORD dwParallelVportControl;
    DWORD dwPerspectiveVportControl;
Expert Elite Member
_gile
Thanks, I finally solve it P/Invoking acedSetenv.
Gilles Chanteau
GileCAD
GitHub
”Boost
