Hello,experts
this is a screenshot of the dwg-file。
I want to change the value of user1 through .net API(user1 is a User Variables),my purpose is to change the length of the line.could you tell me the code ? Thank you very much!
using System; using System.Collections.Generic; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; using AcRx = Autodesk.AutoCAD.Runtime; using AcAp = Autodesk.AutoCAD.ApplicationServices; using AcDb = Autodesk.AutoCAD.DatabaseServices; using AcGe = Autodesk.AutoCAD.Geometry; using AcEd = Autodesk.AutoCAD.EditorInput; [assembly: CommandClass(typeof(Rivilis.UserVars))] namespace Rivilis { public class UserVars { [CommandMethod("ChangeUserVar")] public static void ChangeUserVar() { AcAp.Document doc = AcAp.Application.DocumentManager.MdiActiveDocument; AcEd.Editor ed = doc.Editor; AcDb.ObjectId idNet = AcDb.AssocNetwork.GetInstanceFromDatabase(doc.Database, true, null); using (AcDb.AssocNetwork pNetMain = idNet.Open(OpenMode.ForRead) as AcDb.AssocNetwork) { AcDb.ObjectIdCollection ids = pNetMain.GetActions; if (ids.Count == 0) { ed.WriteMessage("\nNo user variable is found!"); return; } List<string> varsName = new List<string>(); using (AcDb.AssocNetwork pNetSub = ids[0].Open(OpenMode.ForWrite) as AcDb.AssocNetwork) { if (GetVars(pNetSub, ref varsName, ref ids) == 0) { ed.WriteMessage("\nNo user variable is found!"); return; } } AcEd.PromptResult rs1 = ed.GetString("\nVariable name: "); if (rs1.Status != PromptStatus.OK) return; string varName = rs1.StringResult; if (!varsName.Contains(varName)) { ed.WriteMessage("\nVariable {0} not found", varName); return; } AcEd.PromptResult rs2 = ed.GetString("\nVariable expression: "); if (rs2.Status != PromptStatus.OK) return; string varValue = rs2.StringResult; int i = varsName.FindIndex(delegate(string s) { return s == varName; }); if (i >= 0 && i < varsName.Count) { using (AcDb.AssocVariable pVar = ids[i].Open(OpenMode.ForWrite) as AcDb.AssocVariable) { string errmsg = string.Empty; try { pVar.ValidateNameAndExpression(varName, varValue, ref errmsg); if (errmsg == string.Empty) { pVar.SetExpression(varValue, "", true, true, ref errmsg, true); ResultBuffer evalVal = null; pVar.EvaluateExpression(ref evalVal); pVar.Value = evalVal; } else { ed.WriteMessage("\n Error in ValidateNameAndExpression = {0}", errmsg); } } catch (System.Exception ex) { ed.WriteMessage(ex.ToString()); } } } } } ////////////////////////////////////////////////////////////////////////// // Function get lists of variable names and its ObjectIds ////////////////////////////////////////////////////////////////////////// private static int GetVars(AcDb.AssocNetwork pNet, ref List<string> names, ref AcDb.ObjectIdCollection ids) { names.Clear(); ids.Clear(); AcDb.ObjectIdCollection idsActions = pNet.GetActions; for (int i = 0; i < idsActions.Count; i++) { using (AssocAction pAction = idsActions[i].Open(OpenMode.ForRead) as AssocAction) { AcDb.AssocVariable pVar = pAction as AcDb.AssocVariable; if (pVar != null) { names.Add(pVar.Name); ids.Add(pVar.ObjectId); } } } return ids.Count; } } }
Also very useful link:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
