.NET
.NET
dreamwtx
Message 1 of 7 (400 Views)
How to change the layer to be on or off using c#.net ?
400 Views, 6 Replies
03-08-2012 12:30 AM
I hope that i can implement the function not using dll file in autocad. just carry out it  in  out of autocad  .
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (379 Views)
Re: How to change the layer to be on or off using c#.net ?
03-08-2012 10:15 AM in reply to: dreamwtx
Not sure what you like to do now.
If you don't want to create a DLL but you want to develop in C# then you have to create an EXE and you have to use the COM-interface in such way:
ThisDrawing.Layers("myLayerName").LayerOn = false
Or you use VBA or LISP or SCRIPT or .... Or I'm fully wrong and didn't understand your question correctly, then sorry and please try to explain a little bit more detailed what you want to get.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
arcticad
Message 3 of 7 (376 Views)
03-08-2012 10:52 AM in reply to: Alfred.NESWADBA
I posted some code over here just a few minutes ago.
http://forums.autodesk.com/t5/NET/how-to-access-AutoCAD-2012-from-Vb-net-Standard-Exe/td-p/3363237
(defun botsbuildbots() (botsbuildbots))
dreamwtx
Message 4 of 7 (362 Views)
03-08-2012 05:32 PM in reply to: Alfred.NESWADBA
i  want to develop exe using c# which can call autocad and carry out change of  the property (such as layer on or off ,names of layers).  for example, i have a dwg than contains a few layers ,i wanna to close a layers then saveas a dwg.
  in fact,i am not sure that if the functions can be implemented  using c# and not using dll file. this  is just my idea. i also  don't know this way is wrong or right.  i just borrow ideas from secondary development  for solidworks
dreamwtx
Message 5 of 7 (358 Views)
03-08-2012 06:18 PM in reply to: Alfred.NESWADBA
could  you give me more codes like "ThisDrawing.Layers("myLayerName").LayerOn = false"?
- alfred -
*Expert Elite*
Alfred.NESWADBA
Message 6 of 7 (347 Views)
03-09-2012 12:08 AM in reply to: dreamwtx
you got a link from articad for how to access AutoCAD (COM) from an exe.
Then take the document-object, within that you have a collection of Layers, search your layer (by key within the collection, I called it in the sample "myLayerName") and switch it off (property LayerOn)
There is not more code then the above line necessary to switch off a layer with a name you know.
- alfred -
Alfred NESWADBA
*Expert Elite*
arcticad
Message 7 of 7 (337 Views)
03-09-2012 06:35 AM in reply to: Alfred.NESWADBA
http://www.developerfusion.com/tools/convert/vb-to-csharp/
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
